Megasquirt Tubbed 323 Video MS1 v3.0
Old Aug 29, 2008 | 05:29 AM
rx3_pp's Avatar
Hey Guys this is me cranking my 12a PP Turbo megasquirted now it is zeroed at fixed at -5 but not starting im using engine start at the moment as you can here its firing just not quite catching
See if you have some thoughts
http://www.youtube.com/v/Uw8txOUbXmU
And some pics to tease with it is a
1983 Mazda 323 2 door wagon
Number Plate TUBD32
It has rear tubbed 15 x 14" rims and tyres
Street Legal
12a PPT
LSD
Holden Brakes
Attached Thumbnails Tubbed 323 Video MS1 v3.0-tubd32-2.jpg   Tubbed 323 Video MS1 v3.0-tubd32.jpg
Old Aug 29, 2008 | 04:27 PM
rx3_pp's Avatar
need more fuel ? i think its not enough engine start
My fuel pump crapped out so i cant hook up the injectors yet
Old Aug 31, 2008 | 12:26 AM
rx3_pp's Avatar
well got her to fire up all it needed was a teaspoon of oil in each rotor to seal the new apex seals with the new housings
heres a small vid of it firing and dying had it running for about 10 minutes after this vid loud as it is off the turb manifold didnt wanna put the turbo on until it was running good
http://www.youtube.com/v/fjGutABm278
Old Aug 31, 2008 | 08:02 PM
rx3_pp's Avatar
righto got a fuel pump now so will fire her up tonight with the injectors in there and see how we goo wish me luck
Old Aug 31, 2008 | 10:38 PM
muythaibxr's Avatar
MegaSquirt Mod
Sounds like you're almost there!
Old Aug 31, 2008 | 11:29 PM
rx3_pp's Avatar
Yeah thanks muay i hope so soon find out tonight just got my map sensor bung for the plenum and a fuel pump so should fire up straight away
i seem to be getting 7.7ms pulse widths at cranking is this okay ?
Old Sep 1, 2008 | 03:14 PM
rx3_pp's Avatar
Righto i have it firing hard now but it wont run its actually firing up solidley but not to a point of running
ok i noticed my IAT wasnt hooked up using a rx7 one with resistor changed but it wasnt hooked up would this cause it no to start ?
i cant datalog export as my laptop doesnt connect to the internet
im pulling the turbo manifold off to finish munting the turbo on it at a different angel to allow the water pump to fit better
Prediict
32
Nov 18, 2015 08:41 AM
Wicked93gs
42
Oct 7, 2015 11:58 PM
Jmpabon93
Sep 30, 2015 04:57 PM
