West RX-7 Forum Serving California, Nevada, Arizona, Hawaii
SevenStock I-10 Caravan
Old Aug 21, 2008 | 06:00 AM
Rx7_Nut13B's Avatar
Red Neck Tony Stark - C2
Well it is just over a month till Seven Stock.
For the people that are planning on going to Sevenstock and want to caravan down I-10 together as a group this is the thread for the West section. There is a going to be one in each of the sections in the I-10 Cora door
As the event draws near we will have a better understanding of who wants to join in and where the can meet up with the group on I-10.
From Houston there are about 4-5 People and 3-4 cars that will be heading to Irvine with a few more meeting up in the San Antonio area.
If there is anyone that is planning on driving to SS please post in here so we can keep track and try and get a good caravan together
West Section (CA, AZ) https://www.rx7club.com/showthread.p...91#post8482391
Mountain Section (NM) https://www.rx7club.com/showthread.p...89#post8482389
Southeast Section (GA, FL ) https://www.rx7club.com/showthread.p...85#post8482385
South Section (TX, LA, MS) https://www.rx7club.com/south-rx-7-forum-34/sevenstock-caravan-thread-780238/
Old Aug 21, 2008 | 06:18 AM
Rx7_Nut13B's Avatar
Here is the Checklist (http://sevenstock.org/node/view/13) for preparing your cars for the long trip.
Give the car a FULL inspection. Look at everything that moves and replace or repair anything that's suspicious.
* Change the oil
* Change the plugs
* Inspect or replace plug wires
* Inspect your brakes and change fluid
* Inspect clutch hydraulics and change fluid
* Flush the cooling system and use Water Wetter and antifreeze
* Replace thermostat with genuine MAZDA thermostat and inspect your filler cap
* Check all hoses under the hood for dry rot or softening
* Inspect or replace all accessory belts
* Replace fuel filter if not new
* Check all electrical connectors and clean if necessary
* Inspect and test battery and battery cables and terminals
* Have your A/C system inspected and checked for proper pressure
* Change transmission and differential fluids. Use Redline or Royal Purple to refill.
* Inspect all tires including the spare for pressure and tread depth
* Check your jack and tire changing equipment
* Have your alignment checked. Replace any out of spec items.
* Balance your wheels
* Check all of your lights for burned out bulbs
Below is a list of items to take with you on the caravan itself
* 2 Gallon jugs of water
* Small cooler with soft drinks and water
* Set of tools including: screwdrivers, pliers, electrical tape, wrenches and sockets (most common sizes: 8mm, 10mm, 12mm, 14mm, 17mm, spark plug socket)
* Two extra quarts of oil
* Small fire extinguisher
* Spare radiator cap
* Brake fluid
* Road Atlas
* Spare spark plugs
* Jumper cables
* Motorola Talkabout Radio and extra batteries
* GPS unit
* Radar detector
* Hand cleaner and shop towels
* Haynes manual for your car
* Extra fuses
Old Aug 23, 2008 | 07:18 AM
Rx7_Nut13B's Avatar
To the top.. There has got to be someone making the trip down I-10 Also
Old Aug 31, 2008 | 05:53 PM
cozmo kraemer's Avatar
Darkside FD
I will be, from AZ to the area on Friday afternoon sometime.
Old Aug 31, 2008 | 06:24 PM
RCCAZ 1's Avatar
Hey Brian,
The typical Phoenix group will be heading out Friday morning, leaving from The Cracker Barrel on I-10 and Litchfield Road (West Side) at around 7 am. Why not take the day off and join us Earlier rather than Later.
Tim
P.S. How's the conversion running??
Edit: Sorry to cross-post, but there's a fairly active signup list for the AZ Caravan on RX-8 Club
http://www.rx8club.com/showthread.ph...66#post2618766
Old Sep 2, 2008 | 04:36 PM
Darkside FD
It's alive! I need some welding done (radiator mounts and exhaust) and to finish bleeding the hydraulics and it will be road worthy.
Old Sep 10, 2008 | 10:46 PM
RCCAZ 1's Avatar
Sounds good Brian. Sorry for not returning your call. Was out of town on vacation all last week. Will try to reach you on your cell sometime tomorrow to discuss caravan details.
fd3CB
SevenStock Archive
Sep 11, 2015 11:12 AM
Murilli
Midwest RX-7 Forum
Sep 3, 2015 09:10 AM
RacerX7fb
48
Sep 26, 2003 03:28 PM
alx
21
Jun 26, 2002 05:11 PM
