A/C Blower motor?
Old May 8, 2002 | 08:17 PM
aborza's Avatar
Question A/C Blower motor?
Recently bot an 86 Sport Coupe with A/C. The blower seems to put out very little air, but I do not know how much is normal. I do not have another to compare it to.
I really do not want to buy a new blower motor, install it and discover the original was ok. So, is there a way to test the blower? Is there something else that could prevent it from blowing hard?
As I move the A/C slider from zero to full blast there is little or no air coming from the vents untill I am at least 3/4 of the way to full blast and at full blast it puts out only a breeze, not a roar, like on modern cars.
Any suggestions? Discussion?
Thanks
Old May 8, 2002 | 08:25 PM
FreedS4's Avatar
Yea, just remove your A/C.
Chris
Old May 8, 2002 | 08:42 PM
HAILERS's Avatar
HAILERS
Yeah. Just go to the wrecking yard. Buy the housing that the blower motor bolts to. There are electronic parts attached to that housing that effect the blower speed and force. I thought it was my Logicon for the longest time. Swapped several. SAme results. The wiring diagram didn't make that much sense to me because I could not located some of the relays and resistors, until it finaly dawned on me those part were attached to the top and back of the blower housing. Its a lot easier to take out of the car than I originally thought. Paid maybe ten bucks for the housing by itself. Blower blows great now. Its probably not the blower or the Logicon slider that is the problem. Go for the blower housing.
Old May 8, 2002 | 09:02 PM
aborza's Avatar
Thanks for the suggestion HAILERS.
Old Jul 26, 2002 | 01:33 PM
J-Rat's Avatar
Alcohol Fueled!
HAILERS, is it real complicated to change that housing? I am having the same problem, I went and got a new fan, but I havent installed it yet.
Rat
Old Jul 26, 2002 | 07:14 PM
HAILERS's Avatar
HAILERS
No its not hard. I thought it would be hard, so I sat around for a year plus before taking action. Swapped the blower motor with no change. Finaly pulled one fromt the wreck yard and it blows hard now.
My 87 manual as you know lacks a little bit in some areas, and info on that blower motor and housing is one. I think the 89 manual has a lot more info on the heater/blower mtr. I think I can change it out in a half hour or so. Not the bitch I thought it was going to be.
Then again you can get unlucky and get a bad one from the yard. I rejected a couple because the resistor near the air inlet looked crummy.
Old Jul 26, 2002 | 11:03 PM
J-Rat's Avatar
Alcohol Fueled!
Thanks HAILERS. I have a donor car that I will be changing the housing in, I know it works since it was running at one time, and the fan worked quite well..
Rat
Old Jul 27, 2002 | 10:25 PM
Six Rotors's Avatar
If your blower motor is still running it is usually one of two problems,failure of the power transistor,or the motor resistor.Both are located on the heater blower.
Old Jul 28, 2002 | 08:33 AM
HAILERS's Avatar
HAILERS
Jpg of the parts mentioned by Six Rotors:
Old Jul 28, 2002 | 11:14 AM
amemiya's Avatar
oh thank god, I thought someone was trying to make a supercharger out of a ac blower motor.
Old Jul 28, 2002 | 06:32 PM
J-Rat's Avatar
Alcohol Fueled!
You mean it wouldn't work?!?!?!
Old Jul 28, 2002 | 06:55 PM
HAILERS's Avatar
HAILERS
Welllllll......at least you'd get more volume. By the way, on the jpg I marked one out of two parts right. I'd be nice to just change those two items, except you have to remove the housing to do so. No time saved.
Old Jul 29, 2002 | 12:17 AM
MaxRX7's Avatar
hambre y sueño
it is a very easy swap, you just have to get upside on the passenger seat to remove some nuts
Old Jul 29, 2002 | 12:39 AM
J-Rat's Avatar
Alcohol Fueled!
Well, I was going to do it today, but I got lazy..
Old Jul 29, 2002 | 01:58 PM
TRURX7's Avatar
Just be carefull when removing those from the wrecking yard. Some wierd critters like perhaps SNAKES and SPIDERS like making a home there. I been to some yards like this and sometimes I am scared to even pop the hood, afraid a King Cobra is gonna have a go at me like a jack-in-the-box.
Hehe,
Kidding, but stay alert.
TRU
Old Jul 29, 2002 | 02:02 PM
SureShot's Avatar
Seduced by the DARK SIDE
A simple possible cause can be the connector plug on the high speed relay right next to the fan. Check and see if it's burnt.
Old Jul 29, 2002 | 02:06 PM
MaxRX7's Avatar
hambre y sueño
Hehe,
TRU
lol
have no fear,
J-Rat is here
Old Jul 29, 2002 | 02:09 PM
SureShot's Avatar
Burnt - That's southern for burned..
Bill
Old Jul 29, 2002 | 03:18 PM
J-Rat's Avatar
Alcohol Fueled!
Good thing you mentioned that, I wouldnt have thought of it..
Thanks!
RAT
doritoloco
Sep 5, 2015 12:41 PM
