should i get a dp?
Old May 8, 2002 | 08:10 PM
ttb's Avatar
ttb
No Cup Holder Racing
should i get a dp?
my fd has 99k miles on it, original engine, everything stock. my mechanic said the precat is partially clogged. i know i should get a downpipe to replace the precat, but i'm wondering if i should just save save save until the engine goes and do everything at once? or you think getting a dp will help my engine last a little longer? thanks.
Old May 8, 2002 | 08:15 PM
Mahjik's Avatar
Mr. Links
Re: should i get a dp?
I would go ahead and get the downpipe. However, if you don't already have a boost gauge, you should get one of those as well.
Old May 8, 2002 | 08:24 PM
JConn2299's Avatar
reliable performance
Get the downpipe right away. Doing that may let your engine live a lot longer than you think.
Old May 8, 2002 | 08:32 PM
rynberg's Avatar
Get one now. Get a nice SS one, like Bonez, M2, or Pettit. They fit well and will last longer than your car.
Old May 8, 2002 | 08:33 PM
ttb's Avatar
ttb
btw, how much does installation cost? i know the dp ranges from like 200 to 600.
RX7GT's Avatar
...must be a conspiracy
Go for the downpipe now. I had a clogged pre-cat in my 90 T2 and it caused more heat to build up in the turbo and the motor. It eventually caused the failure of both due to excessive heat and not enough flow-through. I have since then tubed the cat and cleaned everything out all the way to the muffler cans. I have even noticed a dramatic difference in the color of the oil that comes out after 2500 miles. It was turning black very quickly but it now stays pretty much its original color.
Old May 8, 2002 | 08:35 PM
ttb's Avatar
ttb
sounds good. he recommended getting a radiator first i think, but i think i'll get the dp first.
Old May 8, 2002 | 11:01 PM
rynberg's Avatar
TTB: if you don't want to try to install it yourself, give Ivan in Sunnyvale a call. He'll probably install it cheaper than anybody else and he knows FDs like the back of his hand. Don't have his phone# on hand, do a search in the west forum.
Old May 8, 2002 | 11:07 PM
mightyslash's Avatar
Will Work for Ferrari
That's not true.
Mahjik's Avatar
Mr. Links
It shouldn't cost more than an hours worth of labor, so at most $100. I had my entire exhaust system installed for around $250.
Old May 8, 2002 | 11:11 PM
Also, if you want to be completely safe, do some fuel upgrades or change the ECU.
