ECU issues when going carb'ed?
Old May 8, 2002 | 06:14 PM
FC3AZ's Avatar
What exactly do you guys do with the unused connections when you do a carb setup on an n/a 13B? I am considering this for my project car. I am dreading hooking everything back up to the used motor I am getting. It looks like a pain in the ****.
Old May 9, 2002 | 10:09 AM
vaughnc's Avatar
knowledge junkie
2 ECUs in the car. One controlls the accessories the other controles the engine. Just remove it.
Old May 9, 2002 | 10:13 AM
RETed's Avatar
If you're going to keep the stock ECU for ignition control, you'll just need to "tie back" all the fuel control wires.&nbsp I've heard that power transitors don't like to be left "floating", so it's recommended to run "dummy loads" on the fuel injectors leads just to keep the power transitors happy.&nbsp I'm sure someone with better EE knowledge might be able to confirm or refute the dummy load recommendation...
-Ted
Old May 9, 2002 | 10:23 AM
blu_gxl's Avatar
why not just run a couple of msd or crane boxes right off of the batt. is this a street or race car or both? if it's going to be on the street at all i suggest going with what ted recomends but if it's just race only car gut all that electrical stuff out.
edit: so i don't get flamed you will need to use coils as well for you spark plug wires
james
Queppa
Nov 18, 2024 03:47 AM
Rotospectre
Mar 28, 2018 03:33 PM
Jun 26, 2016 10:21 AM
Microtech
30
Apr 23, 2016 06:37 PM
FB_Frank85
Aug 31, 2015 03:31 AM
