shocks
Old Aug 14, 2008 | 04:50 PM
jgkiller13's Avatar
shocks
Where can I get new shocks for my 3?? Any websites that you guys know of or stores. I'm looking for some koni's....thx
Old Aug 14, 2008 | 04:57 PM
BENDER420's Avatar
Give these guys a try!
http://classicgarage.com/rx32.html
Old Aug 14, 2008 | 05:15 PM
Re-Speed.com's Avatar
Research classic garage before you purchase. Some have experienced problems with them since they are NOS without factory warranty.
https://www.rx7club.com/showthread.p...ssicgarage.com
We offer spacer to use Tokico shocks from a 1981-1985 Rx7 in your stock strut housings:
http://mrcmfg.com/catalog/index.php?cPath=106
-billy
Old Aug 14, 2008 | 05:54 PM
jgkiller13's Avatar
shocks
so I can use these spacers with my stock rx3 housing, and purchase some early model rx7 tokico shocks and I'll be good? Also, what can I do for the rear?
Old Aug 14, 2008 | 06:14 PM
blackdbl0si's Avatar
www.rockauto.com
Old Aug 15, 2008 | 08:33 AM
Yes with one issue. The Rx7 shock will not mat with your upper mount. You can convert to our camber plates and we can turn the shocks to mate up with them.
The rears should not be hard to find from another vehicle. It will be a simple through bolt mount on the bottom and a stud mount on the top. Pretty standard for a shock. Just make sure to get something with the same compressed and extended lenght.
-billy
Old Aug 15, 2008 | 11:09 AM
BENDER420's Avatar
@bwaits
Thankx for the info on Classic Garage's stock!
Glad someone is looking out for us
Old Aug 15, 2008 | 12:44 PM
Siraniko's Avatar
RX for fun
Jg
No matter if you use the REspeed spacer and 1st gen Tokico on a stock RX-3 strut tube is that you will still have a shitty brakes. Your other options is to modify a 1st gen strut tube with RESpeed camber plate:
1. Without RESpeed spacer: Extend the first gen strut tube (cut and re-weld) and use RWD 626 koni insert. Same diameter as 1st gen but the lenght/travel is the same as the stock RX-3.
2. With RESpeed spacer: Just like above, but use 1st gen Tokico.
If you need to see them, I have both modified struts handy. You got my #.
LongDuck
Oct 7, 2015 08:12 PM
Ernstudet22
Sep 14, 2015 09:19 PM
