Power FC Egt
Old May 8, 2002 | 06:54 AM
kempo's Avatar
Egt
what EGT are you guys having on your engines?. and what should be the highest EGT that i should let my engine run when tuning my PFC?
thanks
Old May 8, 2002 | 12:52 PM
cewrx7r1's Avatar
Eye In The Sky
My last EGT test gave a maximum of 825F after a 0 to 150mph sprint with AFRs in the 11.8 to 11.4 range at 12.5psi boost, non-seq, about 320rwhp.
Old May 16, 2002 | 10:09 AM
jspecracer7's Avatar
1JZ powered
Re: Egt
thanks
Don't necessarily shoot for a number. All EGT's are different since placement is important. Tune your setup to be slightly rich. Do a 1st thru 3rd gear run and see where your EGT is. Back off the fuel until you start to back up again. At this point, you should be running a little lean. Go ahead and re-add a little fuel. That's what I've been doing with my setup and all's well here
...all of this said while knocking on wood...
Turblown
Vendor Classifieds
Oct 17, 2020 03:25 PM
immanuel__7
Megasquirt Forum
Aug 22, 2015 09:34 PM
