Is an EGT required if you're upgrading the turbo?
Old May 8, 2002 | 03:36 AM
WhiteRx7's Avatar
Does the egt come with a sensor? where would the sensor be located, in the exhaust by the o2 sensor?
Boy, I'm still up at this hour working on the car.
Old May 8, 2002 | 04:15 AM
jspecracer7's Avatar
1JZ powered
Your buying a new EGT gauge? If yes, then yes...
It should be as close to the exhaust ports as possible.
Old May 8, 2002 | 01:42 PM
LLADNAR's Avatar
Re: Is an EGT required if you're upgrading the turbo?
my autometer did not come with the temp probe,,make sure you buy a gauge kit,,all i got was just the gauge and the control module.
Old May 8, 2002 | 02:59 PM
UniqueTII's Avatar
Slow and old
Do you have a downpipe on your car? I think the RB DP comes with a spot for the EGT sensor, but you may need an adapter. CNYRX7tech has an Autometer (I think) EGT on his TII with a full 3" RB system, and he had to do some work to get the sensor to fit.
Old May 8, 2002 | 04:58 PM
LLADNAR's Avatar
i just drilled a hole in the pipe and mig welded a nut on the pipe and screwed the egt probe in,,no sweat.
Old May 8, 2002 | 05:54 PM
UniqueTII's Avatar
Slow and old
That works too. I think the RB opening is a little far from the end of the pipe, anyway.
Old May 8, 2002 | 08:20 PM
Bambam7's Avatar
I came, I saw, I boosted.
6 inches from the ports is good, for FINE tuning, but the temp probe won' last very long at all... once you are tuned finely, you can move it to about 12-16 inches from the ports to increase life.
Engine Management Forum
11
Nov 9, 2015 01:15 PM
MoTeC
Sep 10, 2015 07:58 PM
immanuel__7
Megasquirt Forum
Aug 22, 2015 09:34 PM
