Megasquirt Missing tooth with second VR
Old Aug 12, 2008 | 04:40 PM
rx3_pp's Avatar
Last Post i promise
If i have missing tooth CAS i now have the other LM1815N Circut in place can i use a configiration to use this CAS with the missing tooth NE+ and NE - and also have the G+ and G- running ?
Or do i need another CAS
Old Aug 13, 2008 | 06:38 AM
Jobro's Avatar
SAE Junkie
I think you just want a new cas.
Old Aug 13, 2008 | 08:03 AM
toplessFC3Sman's Avatar
that would depend on which teeth are cut out, and would screw up the counting so that you couldnt use the typical 1-3-7-9 or 11-1-5-7 settings and you'd have a 10 tooth main wheel (not 12), but as long as the CAS is positioned in such a way that a tooth passes approx 60-75* BTDC and there is another tooth at approx 0* BTDC (if you use trigger return for cranking), it *should* work... although your RPMs may jump around quite a bit whenever those missing teeth pass, and this'll cause all sorts of issues that look like noise.
Overall, you're probably a LOT better off going with an unmodified CAS though, its tried and true, and one less source of headaches later.
Old Aug 13, 2008 | 03:38 PM
rx3_pp's Avatar
cool i have both circuits now so i will get another CAS what is SPR1 that it says to connect to from the 2nd VR ? what pins do the IAC series come out on ?
Old Aug 13, 2008 | 11:47 PM
they come out on 2-5 IIRC, but i'm not positive on that. Just check them with your multi-meter or look at the pin-out at the end of the V3 assembly instructions online.
Old Aug 14, 2008 | 06:11 AM
rx3_pp's Avatar
So what pins do IAC1A and IAC1B 2A and 2B come out on and for the second VR for the shielded cable on the plug does the G- go to any spare earth pin i have VR2 in G+ on IAC1A and the ground to IGN for the LM1815N But where do i put the G- on the plug NE- is pin 7 ? and the VR2 out from the 1k resistor is to pin 11 of the CPU correct i soldered it direct to pin 11
Turblown
Vendor Classifieds
Oct 17, 2020 03:25 PM
Smokeyfb33
Old School and Other Rotary
Oct 1, 2015 12:10 PM
GKW
Sep 28, 2015 04:34 PM
