Will this work??
Old May 7, 2002 | 07:18 PM
dvls-7's Avatar
Sick & Twisted
Question Will this work??
Heres a pic of a msd box i basically got for free.....will it work on my 7 or not.....I know its for direct ignition but is it good enough for a 7?.....or is my 7 stock ignition better than this box?.....thanx for your input guys.....
Old May 7, 2002 | 10:17 PM
vaughnc's Avatar
knowledge junkie
Old May 8, 2002 | 05:04 PM
dvls-7's Avatar
Sick & Twisted
Old May 8, 2002 | 08:14 PM
dvls-7's Avatar
Sick & Twisted
Originally posted by vaughnc
Can someone help me out......has anyone seen or used this msd unit.....is it good for rotarys or not.....don't want to go through installin to find that its no good or worse does some form of damage.....
Old May 9, 2002 | 08:46 AM
vaughnc's Avatar
knowledge junkie
Who makes the name brand one and who makes this one?
Old May 9, 2002 | 08:59 AM
KNONFS's Avatar
B O R I C U A
I believe it will work. Thats a Digital MSD, the equivalent to the Crane (that thing cost over $200).
You may perform a search under RETED and CDI boxes.
Old May 9, 2002 | 10:53 AM
RETed's Avatar
Wow, that's a $300+ ignition box you got for free?!?!?!&nbsp You sure it still works?
Now, he's the bad news - you can't use it with your stock leading coil unless you buy a pair of single-tower coils for just the leadings.&nbsp "Cheap" MSD coils run about $50 each; so for under $100, you got yourself a bulletproof CDI leading ignition.&nbsp To get the DIS-2 to fire properly, you need to toggle the settings to "wastespark".
On the other hand, you can basically splice the DIS-2 into the trailing coils.&nbsp You have two separate trailing coils, so there is no need for aftermarket coils in this case.&nbsp The downside?&nbsp You get very little power gains firing the CDI box into the trailings; installing the CDI box on the leadings get you the most gains...
-Ted
Old May 9, 2002 | 05:31 PM
dvls-7's Avatar
Sick & Twisted
Thanks Ted......now i guess i jus need to go install it when i get those coils.......
maikelc
Aug 24, 2015 11:04 AM
