pic request: fc DRIVER side washer reservoir
Old Aug 8, 2008 | 11:10 AM
88rxn/a's Avatar
tom port.. AKA streetport
i need to make a intake for my TII and want to keep my washer fluid intact. ive seen a FEW (not many) pics of the washer reservoir mounted under/near the leading coil. im wondering if I could use my passenger mounted washer on the driver side? im not looking for an aftermarket or a 20OZ. bottle trick. id like to use a STOCK reservoir and pump.....so if you have one please post a pic or let me know if its different than the passenger side one....
thanks......
Old Aug 8, 2008 | 01:17 PM
SDrotary-FC's Avatar
@ pipnorcali
this guy used the headlight washers res. instead (off a gxl) might work for ya, or i think early 86's had the res. on the other side.
https://www.rx7club.com/showthread.p...0&page=5&pp=15
Old Aug 8, 2008 | 07:11 PM
InsomniacFC's Avatar
Will drive for parts
86 GXL that needs some engine bay spring cleaning.
Old Aug 8, 2008 | 10:32 PM
88rxn/a's Avatar
thanks for the link...thats pretty much exactly what i want to do!! satanicmechanic ^^^ so that a overflow COOLANT tank correct? it looks like the line on the top of that tank runs to the RAD??
Old Aug 8, 2008 | 11:39 PM
Yes, that's correct. The hose runs back to the filler neck on top of the motor. I might have a picture of that if you want it.
Old Aug 9, 2008 | 10:49 AM
88rxn/a's Avatar
thing is im trying to find out if just the brackets are different between the passenger side and driver side. or are they totally different? im planning to make a CAI like in that link and want to keep the washer fluid,do you still have your washer fluid reservoir?? i couldn't see it in your pic?
Old Aug 10, 2008 | 08:29 AM
The washer fluid reservoir is still in there, but it's hidden behind the passenger side headlight. I'll take some more pictures of both this weekend and post them up.
Old Aug 10, 2008 | 10:32 AM
Aaron Cake's Avatar
Engine, Not Motor
Ended up finding on picture:
Old Aug 10, 2008 | 02:59 PM
88rxn/a's Avatar
perfect...thanks arron.
im assuming the pass. side wont bolt the same on the driver side (use mine on the driver side)?
Monsterbox
Jul 29, 2022 10:48 PM
