Sponsored by: CARiD
SEVERE crushed needle bearings:
Old Aug 2, 2008 | 04:57 PM
K-Tune's Avatar
FD Daily
guessing the bearing fell, got crushed,and then disintegrated, the debris came up through the oil pickup and got sent to the front rotor.
the eccentric shaft is fine,as well as the front and rear main bearings, but the rotor bearing pictured, as well as the other rotor bearing(no scoring, but a lot of brass showing) are trash.
engine ran "OK" like this. produced a noise with the clutch pedal depressed, as well as changing the idle rpm with the clutch in/out
Old Aug 2, 2008 | 04:58 PM
K-Tune's Avatar
FD Daily
Old Aug 3, 2008 | 08:31 PM
P'cola FD's Avatar
Hamado things my way!
Kurt, for future reference, to avoid this happening, make sure to assemble all of the front cover stuff, and tighten the front hub bolt with the rear of the engine facing down. That way, there is no way the needle bearings can get off-center and pinched by the spacer.
Old Aug 3, 2008 | 08:53 PM
K-Tune's Avatar
FD Daily
i thought i was careful about it :[ with my fancy engine stand adapter and everything.
cooldude
West RX-7 Forum
Oct 3, 2015 09:17 PM
