11x18 and 13x18 on burnout Fd?
Old Jul 31, 2008 | 06:23 AM
vest_racing's Avatar
Is this possible?
Where thinking of the coilovers in the rear..
In front I think it will work, just have to find out what ET to use..
Old Jul 31, 2008 | 12:19 PM
ARD T2's Avatar
Not without using some seriously stretched tires and camber.
In order to fit 13's in the back you need about a 50-60mm widebody. i.e Petit Flares.
The Burnout Rears are only about half of that. Typically 11's with MAX GRIP Fitment is what i've seen work. If you camber and stretch maybe 11.5 or 12's.
Rishie
Old Jul 31, 2008 | 01:23 PM
Rishie
Thanx..
Than we have to do some modifying...
Old Jul 31, 2008 | 02:28 PM
I have done some measuring and think I could fit the wheels..
13x18 et25 in back.
11.5x18 et 25 in front.
I will order the wheels in et 40 than I can use some spasers..
If I don`t have done anything wrong..
Old Jul 31, 2008 | 02:32 PM
ARD T2's Avatar
Just remember that when it comes to TOTAL SPACING of the wheel
11.5" Wheel is actually about 12.5" wide from outer edge to outer edge.
13" wheel will be 14" total spacing.
Please rework your math so the backspacing is accurate.
Also take into consideration any alignment changes that might occur under suspension compression. Also check for LOCK TO LOCK STEERING MOTIONS.
Rishie
Old Jul 31, 2008 | 02:37 PM
Rishie
In the front there is no problem, I have the tube frame...
It`s in the back I`m worried about, that it will hit the coilovers on the inside.
And this is for a track car so the suspension won`t compress much..
Old Jul 31, 2008 | 02:39 PM
ARD T2's Avatar
Got it, cool. Just helping where i can. I love my wheel fits.....
Old Jul 31, 2008 | 02:42 PM
Yes and thanx
I just don`t want to hear that it won`t fit....
Old Jul 31, 2008 | 04:30 PM
Does anyone now how much room there are form the brakedisk and in to the dampers on the FD?
Old Jul 31, 2008 | 08:04 PM
ARD T2's Avatar
With aftermarket Trailing arms we've fit
10 +52 as the max backspacing.
i'm calculating that as approx: 7.5" BS Approx.
But there are definitely threads on here to find the exact info.
Rishie
ARD T2's Avatar
This is from ROTOR HAT, not the disc btw.
Rishie
Old Jul 31, 2008 | 08:28 PM
Thanx ARD T2..
I think I will wait until I have got some coilover, so I can do exact measurments..
U have stance don`t u?
Do u sell just the rear coilovers?
I was thinking of the GR+3way..
Old Dec 23, 2008 | 05:09 AM
wpg_rx7's Avatar
if you aint 1st your last
19x12-36 rear 19x10 0 front
would these rims fit for the widebody burnout kit i want or would i need the petit fenders? the rim stiucks out 2 inches from the rear fender. idont have the burnout rear fenders to try them maybe u can help.
Old Dec 23, 2008 | 07:10 AM
R-R-Rx7's Avatar
Rotor or no motor
that is just one sick set of wheels
Old Dec 23, 2008 | 07:48 AM
RA8225's Avatar
Banned
Send me some of those 100's
Old Dec 23, 2008 | 04:55 PM
what wheels is it?...
Old Dec 23, 2008 | 08:12 PM
wpg_rx7's Avatar
volks vsxx
Old Dec 31, 2008 | 09:42 AM
Originally Posted by wpg_rx7
volks vsxx
Me want...
Old Jan 6, 2009 | 11:24 AM
owen is fat's Avatar
those baller work wheels will NOT fit no way in hell with just a burnout rear fender.
they have a negative offset that would stick out more than 2" from the stock fender.
those are calling for you to man up to a pettit flare!
sick wheels though.
or just put some 235's on 'em and rock negative camber until you get them to tuck.
Old Jan 6, 2009 | 08:42 PM
money's Avatar
John Dillinger
sorry.. but i need to borrow this thread.
so if u want to rock on 12 wide wheels with burnout rear fenders... what DO U HAVE TO DO?
Old Jan 6, 2009 | 11:48 PM
johgar's Avatar
Garage_Techno
^^^^ About +25 offset for 12" wide for rear.
Old Jan 16, 2009 | 04:08 AM
DK's Avatar
DK
40k worth of fail
volks vsxx
no such thing!
Work VS-XX... except those are them, either.
Old Jan 16, 2009 | 11:08 PM
wpg_rx7's Avatar
sick wheels though.
Ya I'm gonna have to rock the pettits rear fashure but the front still debating on panspeed or shine front fenders cus the shine don't match up with the pettits!
Old Jan 17, 2009 | 08:15 PM
silverTRD's Avatar
Time or Money, Pick one
which shine's? he makes 2 replicas i believe. the burnout, and c-west maybe?
Old Oct 27, 2009 | 10:58 AM
Black7Conv's Avatar
sorry ..but i have to borrow that thread too...
will 11x18 -22 and 13x18 -22 work on Origin Fd? (+25mm front +50mm rear)
Thanks,
George
