New Engine Started! (Video)
Old May 7, 2002 | 12:15 AM
Jedon's Avatar
Slave2TheFD
http://www.nopro.com/~jedon/RX7_Firs...t_5_4_2002.WMV
Old May 7, 2002 | 12:26 AM
GsrSol's Avatar
Z06 powered FD
I don't know about ours but most cars have the oil pickup in the front of the oilpan, right?
Meaning it isn't good to have a car running with the front jacked up like that.
Old May 7, 2002 | 12:46 AM
Jedon's Avatar
Slave2TheFD
Only ran for about 5 minutes at idle, should be ok.
Old May 7, 2002 | 01:13 AM
93TTRX7's Avatar
is it supposed to smoke like that?
Old May 7, 2002 | 01:23 AM
AdamP's Avatar
If you lubed up everything like you should when rebuilding it it will smoke like crasy for the first little while.
Old May 7, 2002 | 04:27 AM
user 84205's Avatar
ADAMP is right... If it dont smoke it aint going to last very long...
Old May 7, 2002 | 09:43 AM
1bad7's Avatar
haha, your a pretty big guy
how do u fit comfortably in that thing
Old May 7, 2002 | 09:48 AM
vosko's Avatar
Just Call Me Terminator!
i'll check the video when i get home from work. work connection is horrible
Old May 7, 2002 | 10:05 AM
luneytune's Avatar
It's ok as long as the oil pan is full, otherwise you couldn't drive an FD up a steep hill?
That's the very normal first time start smoke - really gets the neibours!
Old May 7, 2002 | 12:04 PM
GsrSol's Avatar
Z06 powered FD
Good point, thanks - no mountains/steep hills around here.
Old May 7, 2002 | 12:40 PM
Jedon's Avatar
Slave2TheFD
I fit fine, I'm 6"1 225. The problem I did have is that no way could I fit in there with a helmet on so I got the Corbeau ForzaII and bolted it right to the floor.
Now if I could just solve my clutch problem I could actually drive it!
http://www.nopro.com/~jedon/engine/clutch.html
-Jedon
Old May 7, 2002 | 04:36 PM
ziftar's Avatar
Rotor Head
Nice purrrrr to it! Its good to see your project nearing completion... mine has just begun. ;D
Old May 7, 2002 | 04:52 PM
Jedon's Avatar
Slave2TheFD
Well if you need any pics or video or parts or other help let me know, I could not have done it without peoples help on the Forum.
-Jedon
Old May 7, 2002 | 10:28 PM
vosko's Avatar
sounds good!
Old May 7, 2002 | 11:31 PM
Jedon's Avatar
Slave2TheFD
Okay that was not really the VERY first time I started it, that was the second time after I moved the clutch fork off the clutch and found the oil and water leaks...
Here is the real first starting.
http://www.nopro.com/~jedon/VeryFirstRX7Startup.mpg
-Jedon
Old May 7, 2002 | 11:53 PM
vosko's Avatar
NIIIIIIIIIIIIICE. ROFLMAO. that's what i expected to see! as long it runs. that's all that matters
quote " honey look the cars on fire!!!!" jk
Kyo
Apr 13, 2019 09:24 AM
rexhvn
Aug 19, 2015 02:59 AM
befarrer
Aug 14, 2015 04:18 PM
