Fabrication Post your questions and projects on Fabrication of Interior or Exterior or custom audio and electronics here.
How TO: Build Turbo Heatshield
Old Jul 30, 2008 | 03:43 PM
Viking War Hammer's Avatar
*** Bless The USA
Exclamation How TO: Build Turbo Heatshield
Ok, here is a very good do it yourself heat shield that anyone could do, and the end result is fantastic, just as good as the real deal if not better,
as there is no welding on it, and wont cost you an arm and a leg.
Go to the usuall shops like k/mart, big-w, target ect... where you will need to find a large bowl, made of stainless steal.
I used a stainless steal bowl of 0.3mm, already polished.
its thick enough to not flex/vibrate/bend, but thin enough to cut easy.
Look for the design you would like and the shape of it, its up to you to find a look that you will like, i bought a plain and simple design, with straight walls, no bends or funny shape design.
You can get aluminium ones, coppers ect... but i think stainless does a better job and ends up looking the best.
You will also need to measure your rear exhaust housing diameter, so as to not get a too small one or too large.
My turbo is 210mm o/d and the bowl i bought is 220mm, so i have a gap of 10mm between my housing and my shield.
Once you have decided on your bowl, you will need to make a template.
I just used a thick cardboard to make my shape. Bend it to the shape you want, and sticky tape the other side on, so as to have the nice bendy/oval shape(see picture).
Put it on your housing and try to get the best possible bend and the look that you want.
Remember to get the width that you desire as well, and the lenght.
On my turbo (gt42) i had small threaded holes on the rear part of the housing, so i shaped the cardboard and made the holes that you see behind it.
This is where i will be bolting up the shield to the housing.
I understand that every turbo is different, but if you have these holes at the rear of the housing, you can measure them yourself and drill the holes to match your housing.
Now that you have a template to make your shield from, its time to cut the bowl to suit.
So measure up your template, put it against the bowl and make the required markings where you will cut it off.
You will be cutting of the head of the bowl(the top part where the handle is), and leaving the bottom part of it so you have something to bolt up to.
I used a cutting wheel on a grinder, taped up the bowl section with masking tape on the part i will use, so not to scratch/damage it, and cut my shape.
Once cut,i used a fine file to get rid of the sharp ends, and then used a fine sanding wheel to get a smooth finish.
I cut the lip at the front of it just a bit, to make it look more professional.
Now all that you are left with is to put to template against the shield and mark the holes where you will drill, remember, put the template on the inner side of the shield when marking(not on the outer side), this will make sure you dont stuff up your measurements.
Once you have drilled the holes, again, sand down the sharp edges that the drill leaves (tip: drill from the outside of the shield as this leaves edges on the inner shield where you dont see it).
Now to find the correct bolt size and thread that will match your housing thread and bolt it on, and your done!!!
Then enjoy the mighty fine look it will give you as well as helping all that heat under your bonnet.
On the australian/RHD, our brake master and clutch master is very close, it helps greatly with this shield.
I couldnt be more happier with the end result.
I paid AU$26 for the bowl, and did the labour myself, so that cost me nothing, In the shops, they are asking AU$250 for this piece.
I have higher resolution pictures, but due to size, i needed to be fair to everyone and made them smaller.
Credit to Bosshog, not me.
Old Jul 30, 2008 | 06:02 PM
jkstill's Avatar
Searching for 10th's
This is a cool idea.
Old Jul 30, 2008 | 06:51 PM
CrackHeadMel's Avatar
Learned alot | Alot to go
wow, great idea, add'd that to the walmart list
Old Jul 30, 2008 | 07:02 PM
darkside7's Avatar
thats awsome.
Old Jul 30, 2008 | 07:15 PM
Azcamel's Avatar
Put it in her butt
wow!!! make me one!! lol, i got a GT42 also.
Old Jul 30, 2008 | 07:46 PM
FD3S4Life's Avatar
There goes a prius!
hrm.....
Old Jul 30, 2008 | 08:59 PM
Scrub's Avatar
bow leggin'
looks great.....but I'm still laughing a bit knowing what it actually is Still great idea though.
Old Jul 31, 2008 | 10:49 AM
2a+RoN's Avatar
haha, awesome.
Old Jul 31, 2008 | 01:12 PM
InsomniacFC's Avatar
Will drive for parts
I'd have left the handle on for lulz. Gread idea btw.
Old Nov 13, 2008 | 11:55 PM
JEROME's Avatar
This is awesome.
Old Nov 14, 2008 | 01:54 AM
RX72NR's Avatar
paying to play
Great idea, you could sell a $10 pot for $500 with very little effort. Just use use both halves.
Old Nov 14, 2008 | 07:59 AM
OTT's Avatar
OTT
Representin since '86
^ sad but true... looks good.
Old Nov 15, 2008 | 12:21 AM
staticguitar313's Avatar
R.I.P. Icemark
this is epic, must do when i do single
Old Nov 16, 2008 | 12:25 PM
87 t-66's Avatar
not a drifter
wow, looks great.
Old Nov 18, 2008 | 09:46 PM
pat-b's Avatar
tricky tricky
Old Nov 22, 2008 | 05:06 PM
MOBEONER's Avatar
It's finally reliable
just wait until your wife finds out what happed to her missing pasta pot...
Old Nov 27, 2008 | 01:06 PM
full-cruise's Avatar
D.I.L.U.S.I.
man that looks realy good lol
Old Nov 27, 2008 | 01:26 PM
dean23's Avatar
pwned
nice! got an otyer walmart goodies to show us?
Old Dec 2, 2008 | 04:10 PM
dj55b's Avatar
now thats ingenius and penny wise at the same time ...
Old Dec 27, 2008 | 05:57 PM
justturbo2's Avatar
Registered User
awsome job.
that's a great idea
Old Apr 26, 2009 | 08:38 PM
13brenova's Avatar
Learns the hard way.....
We used you're technique to make a heat shield for my brother's 60-trim srt-4. Turned out great!
Old May 11, 2009 | 04:55 PM
Barry Bordes's Avatar
"Elusive, not deceptive!”
Eric, nice choice of SS pots.
Have you considered reversing it and shielding the 360º of compressor housing from the radiant heat of the turbine housing?
Barry
Old Dec 6, 2009 | 11:41 PM
speedjunkie's Avatar
Make an assessment...
Veteran: Air Force
That's awesome! I'm gonna do this. I have already been constructing a makeshift airbox from a coffee can and some heat shielding to go around my filter, and hoses coming from the headlights (once I do a headlight conversion). This is so cool though!!!
Old Dec 10, 2009 | 01:09 PM
APEXAP1's Avatar
This is some creative thinking:P
Old Dec 10, 2009 | 02:22 PM
viviorunitia88's Avatar
Boost like crazy
very good idea cant even tell its a pot
