NEED COMMENTS about the setup on my 3rd gen.
Old May 6, 2002 | 08:55 PM
Jordan's Avatar
I have a buddy in California to work on my car, I trust him and I know he's really good with rx7s, but I just wanna have some comments from people about the setup, should I go with it? and how much you think it would cost? I mean if it's a good setup, I'd go ahead and do it. remember I am attempting using it mostly on street, not really racing. (that's why I need some comments from you guys about it)
ok, here's the setup.
> core more and good trans
> rebuild on the core motor(Race Motor)Very
>relaible for the street @ low boost.
> Paint and auto body
> TO6 Turbo Charger, Manifold and Wastegate
> Custom 3" inch Downpipe,Mid pipe and exhaust /w
>high flow edelbrock Muffler.
> for fuel system upgrade(Bosche 800Hp 24 hour
>fuel pump, 570cc Primary, 1680 secondary injectors,
>custom fuel rails, fuel pressure regulator, 1/2 inch
>fuel lines/w return).
> Autronics Fuel management(wired in, all
>triggers, sensors, brackets and dyno tune).
>This combination will give at least 500Hp at the
>crank.
>It is capable of 650rwhp @26Psi.
PLEASE, GIMME SOME COMMENTS ABOUT IT. IS IT A GOOD SETUP?
any comments, I'd appreciate that.
Old May 6, 2002 | 09:28 PM
Brad's Avatar
dear baby jesus...
i dont think a td06 is capable of 650 rwhp @ 26 psi. Not even sure it's efficient at 26 psi...
Old May 6, 2002 | 10:08 PM
user 84205's Avatar
i would have to give that a big NOT. Its hard enough to make 700-750 with a T-51r. TDo6 you might get 500hp unless your perri ported...
Old May 6, 2002 | 10:13 PM
Jordan's Avatar
Yep, I'm getting the perri porting. btw, where can I get more info abou this porting?
and now what do yu guys think? and how much do you think it will cost?
Old May 6, 2002 | 11:18 PM
user 84205's Avatar
$$$$$$ I cant tell you prices for the states$$$$$$
Old May 6, 2002 | 11:22 PM
user 84205's Avatar
I would perri port it though. Unless your just going to race, it but even though. The race teams here dont perri port ****, except drag racers, but you only get a few good runs out of them, then $$$ again. TD06-25g which Im sure your probably getting if you want HP, but not a turbo for Perri. Go sideport/or street as its called in the states....
Shainiac
Jul 17, 2019 02:20 PM
Rdecker20
V-8 Powered RX-7's
May 30, 2018 08:37 PM
