Jspec 13BT Question
Old May 6, 2002 | 08:39 PM
darkwaveboi's Avatar
Need donor car in Fairfax
Jspec 13BT Question
Hey, to those of you who have boughten a JSPEC 13BT (preferably the Series 5, but doesnt matter), Where did you buy it and what tends to come on it? Do they normally come w/ stock turbo and intake/exhaust manifolds? What about Clutch/Flywheel? Im trying to determine what USUALLY comes on them and what company seems to import ones which are least prone to failure (some companies have better hookups i guess). Im lookin at about 1000-1200 for one. Im HOPING that the clutch/flywheel/pressure plate comes on most of them because that'll cut my conversion price down a good 1k.
basically do most engines come in longblock form?
Short Block
Intake Manifold
Exhaust Manifold
Turbo
Clutch and PP?
Flywheel?
Thanks.
Jeff
Old May 6, 2002 | 09:00 PM
turboGXL's Avatar
got mine from fc3s.org. It has 120 psi compression on both rotors and came with EVERYTHING minus fluids, belts and ECU/wiring harness.
Old May 6, 2002 | 09:05 PM
well, dont the belts off the NA fit the TII? ECU and wiring harness arnt an issue..i can haggle em off someone here
Old May 6, 2002 | 10:40 PM
Icemark's Avatar
I have bought a couple now, as TurboGXL says they all have come with everything including the cut engine harness and missing belts, although the last two I got also had bent intercoolers and the oil cooler hoses were just chopped off.
They also had flywheels and counter balances from an automatic which worked good for me because I went with a light flywheel anyway
_Tones_
May 25, 2021 05:37 AM
Nosferatu
Sep 5, 2015 02:13 PM
