My Aragosta shocks - FD3S
Old Jul 28, 2008 | 09:45 PM
FDokinawa's Avatar
Picked up a set of standard Aragosta shocks the other day.. F:10.3 R:7.8 Got them from Up Garage for $1500 they are brand new!
I'll let you guys know how they feel after I get them on..
Old Jul 28, 2008 | 10:38 PM
silentblu's Avatar
do they have anymore/??
Old Jul 29, 2008 | 05:17 AM
FDokinawa's Avatar
no.. but they have another set that looks just like Aragostas.. they want $2000
no idea what spring rate or who makes them.. but other then the tube color and stickers, they look exatly the same.
Old Jul 29, 2008 | 05:54 AM
munroman's Avatar
I have these Aragostas fitted to my FD
see www.stresseze.com.au
I am a novice race driver but having a ball and the car has been doing very fast times here in Australia.
Even with me behind the wheel.
So maybe they are pretty good.
But with my inexperience I am not sure.
Someone told me Mazdaspeed use them?
The springs say Merwede
They are the same colour as the ones you just bought.
The rears say 250 45 75
I assume the 250 is 250mm high but whats the 45 and 75?
Anybody know?
If it is 45 Kg /mm for the first bit of the compression and 75 kg /mm for the second progression etc, what is that in pounds?
I have googled it and researched it for hours but info is scarce.
I would love to know the pound imperial/rating of these.
The fronts say 210 73 103
Does anybody know much about Aragostas?
I have tried to search this site but not much luck other then this new post.
THANK YOU and regards from Down Under.
Old Jul 29, 2008 | 09:28 AM
gracer7-rx7's Avatar
needs more track time
https://www.rx7club.com/showthread.p...light=aragosta
Another review of the same setup.
Old Jul 29, 2008 | 09:42 AM
FDokinawa's Avatar
Munroman... Yea, I did a lot of searching myself, and unless you speak japanese your going to have a hard time finding info on these coilovers.
this is what I got with the shocks..
from what I can translate..
Toe: FRONT IN 2mm REAR IN 2mm
Spring Rate: FRONT 210-73-10.3 REAR 250-39-7.8
Tire Size: FRONT 235/45 R17 REAR 255/40 R17
Tire Pressure: FRONT 2.1 kg f/c REAR 2.1 kg f/c
Shock position:
Street FRONT #8 REAR #8
Winding FRONT #6 REAR #5
Circut FRONT #4 REAR #3
Distance from grount to fender: FRONT 645 REAR 655
How much lower then stock(think thats the translation) 30
How much adjustment you have: FRONT +/- 10mm REAR +/- 10mm
Old Jul 29, 2008 | 09:46 AM
FDokinawa's Avatar
yea.. read that. guy really dindnt have the info I was looking for though.. like hight and spring rate.
Old Jul 29, 2008 | 11:10 AM
fwiw...
The springs look to be a progressive spring on the ones in your first pic. I say that b/c of the way the spring is wound with uneven lengths between the coils. That might be why you are having difficulty figuring out the spring rates and such.
The other set look to have regular linear rate springs.
Old Jul 29, 2008 | 11:21 AM
FDokinawa's Avatar
fwiw...
mmm good eye.. I'm going to try these springs out for a while and see how I like them. If I need to I'll just have them revalved and get new springs.
Have we figured out what is better? progressive or linear? or is it still what the driver likes? think the shocks on my car now are linear.. havnt really looked. =/
Old Jul 29, 2008 | 01:30 PM
eoph's Avatar
the other ones you posted are the yumekobo coiloves.
Old Jul 29, 2008 | 01:40 PM
FDokinawa's Avatar
cool.. thanks for the info. =)
Old Jul 29, 2008 | 05:04 PM
Better depends on intended use and perhaps also driver preference with regards to progressive or linear spring rates. They are different and offer different handling and ride characteristics.
Shocks are not progressive rate. Springs are.
Old Jul 29, 2008 | 07:48 PM
munroman's Avatar
Shock position:
Thank you so much. This is more than I have been able to obtain in 9 months of internet searches. thanks!!!!!!!!!!!!!!!!
Old Jul 29, 2008 | 07:50 PM
munroman's Avatar
Thanks mate. I will have to try the search function again. I must be doing something wrong.
Old Jul 29, 2008 | 08:19 PM
N3philum's Avatar
Shikkaku Dori
sweet suspension Bret remember im first in line if you decide to sell em
Turblown
Vendor Classifieds
Oct 17, 2020 03:25 PM
cto_2
19
May 8, 2018 08:15 AM
