'99 rear brakes
Old Jul 27, 2008 | 10:09 AM
rallimike's Avatar
'99 rear brakes
Anyone know what's available in pads for the '99 rear brake calipers, and where to buy them?
Old Jul 27, 2008 | 03:48 PM
gracer7-rx7's Avatar
needs more track time
the 99 RS/RZ calipers use the same pad shape as the 93-95 USDM calipers. I used to have those brakes.
Old Jul 27, 2008 | 03:54 PM
KaiFD3S's Avatar
SINFUL7
yup, they use the same pads as the stock ones...
Old Jul 27, 2008 | 04:39 PM
rallimike's Avatar
Wow. Thanks. What was the point to the larger caliper and rotor, I wonder? How does the same size pad sweep the larger rotor?
Old Jul 27, 2008 | 07:20 PM
sub9lulu's Avatar
do u even know how brakes work ?
one word : leverage
the caliper might even be the same btw
Old Jul 27, 2008 | 09:30 PM
rallimike's Avatar
"do u even know how brakes work ?'
I'm sure no where near as much as you do. Thanks for the generous, if unhelpful, reply.
Old Jul 28, 2008 | 08:41 AM
ptrhahn's Avatar
Actually it's more than just leverage—it's also rotor mass for heat absorption/dissipation.
I most cases, the "problem" with the stock brakes isn't so much braking power, but heat... once you're using them hard enough, you start to crack rotors often—there's just not enough mass. W/ the '99 set, most of the additional mass is added up front with a taller/wider rotor, and the rears are enlarged a bit for ballance.
Marty RE
Aug 17, 2015 09:36 AM
Marty RE
Aug 13, 2015 11:19 AM
