Megasquirt Idle Problem: Movie Enclosed!
Heya.
What does this sound like?
Vac Leak?
Dirty Injectors?
CAS Noise?
Bad PW?
http://rapidshare.com/files/132057355/Movie.wmv.html
Would really love some help!
Vac Leak?
Dirty Injectors?
CAS Noise?
Bad PW?
sounds to me like a vac leak or you're trying to get the car to idle while on a relatively steeply sloped part of the VE table (and the throttle is propped open too far). If it were CAS noise i think you'd be seeing the RPMS jumping around a lot more on MS. Do FB's have their tach's triggered off of the trailing coil in the same way FC's do?
Well, the timing was out by one tooth advanced, no wonder it was pinging at 2k rpm. There was a steep slope in the VE there, and yes the idle speed is high to keep it running. But I think, MAYBE with the noise fix, getting the timing spot on, it might idle, HERES hoping. I will get a new movie if it smooths out.
EDIT: Installing my PCB software again, I'm fairly happy there are no problems. The efan and 2nd trigger input are working on MS2 extra 1.0.2, can't test the boost control but I will just put the default circuit there and hope it works.
LongDuck
Oct 7, 2015 08:12 PM
