Rtek Forum Discuss the Rtek 2.0 and other Rtek ECU's
Rtek Tuning question
Old Jul 20, 2008 | 11:08 PM
duhafnusa4's Avatar
i live at 3200 ft and my AE TII was running rich at 1500ish when i bought it, any recommendations for tuning for running better?
i have the rtek 2.1
Old Jul 21, 2008 | 10:08 AM
turbo2ltr's Avatar
I moved your post as it does not belong under the Rtek FAQ thread.
If you have a 2.1, then simply lean it out at 1500 and the boost that it runs lean at using the fuel correction map.
Old Jul 22, 2008 | 07:07 PM
duhafnusa4's Avatar
thanks my bad
also i was told it was running 10psi also, how can i be sure using the Rtek? isnt 10psi like 500mmHg?
Old Jul 22, 2008 | 07:09 PM
turbo2ltr's Avatar
View the MAP sensor reading.
If you want to show in PSI, set the units to imperial in the preference screen.
mmHg is typically used as a measure of vacuum. Metric pressure is in Bars which is what the rtek displays when above 0 psi in metric mode
Old Jul 23, 2008 | 10:57 AM
duhafnusa4's Avatar
ok thanks figured that out.
i just did a Log to see what my max psi was and the highest it hit was 6.4psi.
i was told w/ the Rtek it should be around 10 right? im going to get a MBC and turn it up to 10 and see if that fixes it
Old Jul 23, 2008 | 11:22 AM
turbo2ltr's Avatar
The Rtek has no control over the boost.
Turning up the boost is typically never a "fix" for anything...well except for the "problem" of running less boost than you want.
Make sure you monitor your AFR with a wideband before turning up the boost. If you value your engine, the boost should never just be arbitrarily turned up without proper monitoring.
Old Jul 23, 2008 | 01:02 PM
duhafnusa4's Avatar
ok then it just displays it i figured out my problem though, the last owner had used electrical tape to block a nipple on the intercooler:S so deffinate boost leak so i fixed that
i went out again(after proper warming of the engine) and found that it runs 9.8-10.3psi. oh i know how stupid it is for people to just "turn up" the boost on thier vehicles because it will lean out and ill be screwed.
you gotta be careful w/ um
Old Jul 23, 2008 | 01:08 PM
duhafnusa4's Avatar
also what would be a good af ratio for when i do increase my psi? 12.2 i seem to remember???
Old Jul 23, 2008 | 07:23 PM
sc0rp7's Avatar
Rotary Adrenaline
10.5-11 is very safe
Old Jul 24, 2008 | 10:47 AM
duhafnusa4's Avatar
ok thanks
Daua118
SE RX-7 Forum
Dec 5, 2021 04:15 PM
Skeese
65
Mar 28, 2017 03:30 PM
Microtech
30
Apr 23, 2016 06:37 PM
