Power FC AC Fix - Idle Problems
Old Jul 21, 2008 | 04:22 AM
Riccardo's Avatar
Dear all
I have recently done the ac fix
https://www.rx7club.com/showthread.p...ghlight=ac+fix
When I turn on the A/C now all numbers work however, often I get erratic idle between 400 - 900 rpm - if I turn the A/C off everything is ok
any views ?
Many thanks
Riccardo
Old Jul 21, 2008 | 04:33 AM
Azcamel's Avatar
Put it in her butt
bump up your idle, go to the setting screen under idle, the last two are for power accessories on idle, try moving it up 100rpms.
Old Jul 21, 2008 | 07:56 AM
Riccardo's Avatar
Thank you Azcamel
Will try it and see if works
Old Aug 26, 2008 | 07:13 AM
Riccardo's Avatar
I have tried it out as well as some further tuning of the idle
Unfortunately, approximately 50% of the time, when I turn the A/C on my iddle hunts between 500 - 1000 rpm
Any further hints ?
Many thanks
R.
Old Aug 26, 2008 | 08:12 PM
cewrx7r1's Avatar
Eye In The Sky
You should try adjusting the Air Adjusting Screw (AAS) under the throttle body to fine tune your idle air flow. You should try both opening it (CCW) or closing it (CW) in 1/4 turn increments untill you get the most stable idle. If neither way works, then you might need either adjusting the idle speed with the commander and or idle fuel.
Old Aug 27, 2008 | 02:42 AM
Riccardo's Avatar
cewrx7r1
Thank you for your response, everything works fine other than when A/C is on (thus mechanical problems are ruled out - we have checked extensively with my mechabnic for theses anyway)
I have played with adjusting the idle speed with the commander and or idle fuel and it works fine, and a few km down the road, for no apparent reason, at the next trafic light it hunts, then again a few miles down the line it is fine again and so on
Old Aug 27, 2008 | 03:08 PM
jmadams74's Avatar
Did you try what Chuck suggested? When your A/C is on (creating load -- and at a slightly higher rpm if you have the pfc adjusted correctly) the idle responds slightly differently than when under no load. Typically, a slight adjustment to the AAS will take care of this. Also, do you have the O2 feedback turned off on the PFC? This could cause a problem like you describe. And one more thought, the idle between 400 and 900 rpm is lower than where I have experienced this problem, is there a possibility you need to increase your idle rpm slightly on the pfc for the a/c on setting? The typical (good) situation is the idle will stop slightly above where you set it, then drop slowly and nicely into a perfectly smooth idle where you have it set on the pfc.
Old Aug 28, 2008 | 07:09 AM
Riccardo's Avatar
I have set it 1000 rpm even higher
Yes it works fine, and then at the next traffic light decides to go its own way...when I turn the a/c off...everything is perfect !
I think I do, I will check however
Do you think this will help
"Your deceleration fuel cut recovery setting may be too low"
Thanks !
DerpyToast
14
Nov 23, 2024 05:19 PM
MazdaspeedR1
The Bad & Fugly Businesses
27
May 22, 2018 05:58 PM
rx7shirley
Sep 2, 2015 02:11 PM
