wat happens when you put in wrong plugs?
Old May 5, 2002 | 10:36 PM
mr. ut's Avatar
what will the engine do if you put the trailing plugs where the leading ones suppose to go and visa versa???
Old May 5, 2002 | 10:53 PM
cmartinp28's Avatar
put in the wrong plugs and you will see peices of your apex seals coming out of your exhaust
Raymr's Avatar
I found mine reversed too, when I bought the car. They were new so I took them out and put them back in the right holes. There was no difference regarding before and after performance. One of them seems to be a hotter plug (can't remember which one), so I think the difference between leading and trailing plugs has to do with the operating temp. they're exposed to, and therefore long-term plug life.
Old May 5, 2002 | 11:31 PM
Scott 89t2's Avatar
SOLD THE RX-7!
probably nothing. I'm running 4 trailings right now.
just don't swap the plug wires around
Old May 5, 2002 | 11:56 PM
gotorx7's Avatar
The 7 can't lose!
I should think that the leading plugs will tend to foul quicker, and the trailing ones to burn out.
But it won't make a huge difference to anything else unless you are already running lean and/or hot...
Old May 6, 2002 | 12:08 AM
RETed's Avatar
Nothing bad will happen...cmartinp28 had been smoking too much crack!
Now, if you get the trailing spark plug wires switched around, this can lead to detonation and eventual engine damage if you don't back off the throttle...
-Ted
Th0m4s
Feb 26, 2019 02:04 AM
diabolical1
30
Jan 30, 2016 05:50 AM
alphawolff
Nov 17, 2015 05:57 PM
PhillyFC
Aug 21, 2015 06:36 PM
