Best brand of DOT 5.1?
Old Jul 15, 2008 | 07:00 PM
blackball7's Avatar
Whats your opinion? I need it for my kart because the silicon DOT 5 sucks donkey ***** and i wouldnt mind having some better pedal feel in the 7.
Old Jul 15, 2008 | 07:30 PM
Roen's Avatar
The Silent but Deadly Mod
The only 5.1 that I know of is Motul 5.1, but I'd rather use their RBF600 or Wilwood's EXP Plus or Castrol SRF which are all DOT 4 fluids.
Old Jul 15, 2008 | 11:05 PM
Black91n/a's Avatar
Forget about the DOT number, it's just a MINIMUM spec. Personally I use Ford DOT3 fluid that I get at the parts store for less than $7 a bottle (bought some today in a Prestone bottle). If you go to Ford to buy it you'll get 500 degree F stuff, as they re-formulated it a while ago, but if you can find it at your local auto parts store, chances are it's the old formula 550 degree F stuff. It does absorb more water than some other fluids, but it's so cheap that bleeding more isn't a big deal at all.
Old Jul 15, 2008 | 11:15 PM
blackball7's Avatar
i dont care about bleeding brakes or how cheap it is. Its going to be used in my kart as well and the DOT 5 silicone crap sucks. the 5.1 holds up to temp and water better. i cant use anything under 5. All the leading brake fluid companys produce it, but i just want to know if you guys think one would be better than the other.
Old Jul 16, 2008 | 11:13 AM
Roen's Avatar
You can use 5.1 in DOT 5 vehicles? didn't know that........since 5.1 isn't silicone-based.....
Motul's 5.1 is only something like 550 F, but their DOT 4 RBF600 is 591 F or something.
Old Jul 16, 2008 | 11:51 AM
blackball7's Avatar
as far as ive been told, Yes.
just going by what i hear at the track. I HATE the DOT 5 silicone crap. It always gives a mushy pedal and is always getting burnt. Im tired of changing brake fluid after every race to have it happen halfway through the next day.
im gonna try and find out more about the kart, but if i have to ill find a way to use something better! lol
Old Jul 16, 2008 | 11:59 AM
Roen's Avatar
Right, I'm still confused as why the kart can't take DOT 4 fluid.....maybe not the baseline ones that have crappy dry boiling points, but an RBF600 (591 F), SRF (574 F) or EXP Plus (620 F) should have high enough boiling points to last in a kart.
Old Jul 16, 2008 | 12:00 PM
ARD T2's Avatar
Just a heads up, I spoke with Motul several years back about the 5.1 and they said your braking system needs to be COMPLETELY CLEAN OF ANY OLD FLUID, OR ANYTHING UNDER 5.1. I can't remember the specifics, but he was basically implying that if you have run something other than 5.1 in the vehicle than you should stick with DOT 4 max. This might pertain to Motul only, but just want you to know so there's no problems with the car.
Rishie
Old Jul 16, 2008 | 12:30 PM
blackball7's Avatar
dont forget, you must look at the wet boiling points too!
i found a great article while searching for different brands of brake fluid:
http://www.stoptech.com/tech_info/wp...fluid_1a.shtml
Old Jul 16, 2008 | 12:32 PM
blackball7's Avatar
Rishie
yes. this is true with all, not just motul or 5.1. You should do this when ever changing from one DOT type to another.
Old Jul 16, 2008 | 12:53 PM
Roen's Avatar
You can mix 3 and 4 without a problem. If you're talking about opitmality then yes.
Old Jul 16, 2008 | 08:35 PM
Black91n/a's Avatar
Wet boiling points are only important if you don't do maintenance. Fresh brake fluid is what you want no matter what, so the dry boiling point is what you'll actually be getting.
Like I said, the DOT# is only the MINIMUM STANDARD, not necessarily what you'll actually be getting. Look at the actual rating on the bottle.
Old Jul 17, 2008 | 12:20 AM
blackball7's Avatar
yes, this is true.
i did, from what i saw, Castrol SRF is the best but 3 or 4 times higher priced.
NEO Super DOT 661 (i think thats the name) is the best for it price.
just what i saw from that stoptech article.
Old Jul 17, 2008 | 05:53 AM
MFP10thAnn's Avatar
ATE Super Blue.
Old Jul 17, 2008 | 08:04 AM
Roen's Avatar
Super Blue's Dry Boiling Point is too low next to the fluids that already have been mentioned.
You mean Neo 610, right? I couldn't find 661 on the internet.
SRF is expensive because it has an ungodly high wet boiling point. You could literally leave that fluid in for god knows how many years.
Old Jul 17, 2008 | 09:49 AM
blackball7's Avatar
yeah thats it.
yeah i know, but i think i would still end up burning that **** in my kart at least, or have some brake failure were we lose all the damn fluid! itd be my luck... lol
Old Jul 17, 2008 | 06:26 PM
Black91n/a's Avatar
That's the one thing that I really like about the Ford DOT3, it has a higher boiling point than some of the expensive race fluids (such as the ATE Super Blue) and is cheap and readily available (well for me anyway, Canadian Tire sells it), so I think nothing of flushing the brakes very thoroughly, and there's no worries about not having enough and needing to order it from far away and waiting for a week or more to get it.
Old Jul 17, 2008 | 07:51 PM
gracer7-rx7's Avatar
needs more track time
WHy not Google for it than post on a forum where few people have any karting knowledge?
http://www.google.com/products?q=dot...num=1&ct=title
Old Jul 20, 2008 | 08:20 PM
blackball7's Avatar
i did, and this is also, more than likely, going to be in my car someday.
