I'm lost...need help!
Old Jul 15, 2008 | 06:51 PM
BigPimpin''s Avatar
I've got a 91 t2 with 79.000 miles on it. The car starts up, idles fine, seems normal untill you pull off. I can drive around the block and hammer it, car boosts up and hauls ***, until about the third time and at about 4k it falls on it's face and cel pops on. The car goes into limp mode and runs like ****.
I can turn it off, start it back and cel goes out, car goes back to boost. I've tried 3 different ecu's, 2 boost sensors. What the hell could it be? Is there any other sensor I'm missing?
Old Jul 15, 2008 | 08:25 PM
Johny zoom's Avatar
BRYAN hope all is well
What check engine code are you getting?. I had an issue with a 90 gxl that sounds similar.
See if its the OMP I have one if you want it.
give me an adress.and if all s5 are the same
jOHNY
Old Jul 15, 2008 | 08:32 PM
misterstyx69's Avatar
Retired Moderator, RIP
yep ..sounds like Limp Mode..omp problem as Johnny Said..I am sort of Glad That I have an S4..as most of the Guys that Have S5's seem to Run into an OMP problem often..
Old Jul 15, 2008 | 09:09 PM
BigPimpin''s Avatar
jOHNY
Thanks Johny! Here's the strange thing..it doesn't give a code. You ground the jumper and turn the key on, the light comes on, goes out, then comes on and stays on. Im baffled.
