quick question about lsds
Old Jul 15, 2008 | 02:23 AM
bokboked's Avatar
So i was just wondering on mazdatrix they talk about the loud noises that are caused by the 1.5 lsd. Just wondering if that happens with the torsen lsd and if the wpc coating that mazdatrix offers is done by them or is it offered through kaaz?
thankssss
Old Jul 15, 2008 | 05:53 PM
fcforlife's Avatar
rotary tech
torsen lsd and clutch lsd are 2 different set ups. are you talking about the noise coming from the mazdatrix clutch type? sorry if this question sounds dumb but im just clarifying.
if you are talking about the mazdatrix clutch type lsd then your answer is that the noise problem won't happen with the torsen. obviously the clutch type uses a bunch of clutches and springs. the fricton from those is what will create noise. there are was to dampen it out. now the torsen on the other hand uses worm gears to limit slip. by useing those gears it one last longer is more reliable and quieter. go with torsen if you can afford it.
SakeBomb Garage
Oct 9, 2015 10:05 PM
ZacMan
Sep 19, 2015 09:20 PM
