FC wont start in the morning cold
Old Jul 14, 2008 | 06:08 AM
amemiya-7's Avatar
RXshun
Arrow FC wont start in the morning cold
My fc wont start when its cold in the mornings, it cranks fine although a bit slow, it will crank slightly faster with the clutch in but will not fire, it will only start if I spray CRC in the intake manifold or unplug the fuel pump relay under the dash and quickly plug it back in as soon as the car fires. the car was also auto but converted to auto if that makes any difference
Old Jul 14, 2008 | 06:15 AM
Karl573's Avatar
Party Animal
You will need to sacrifice 3 chickens and a virgin on the 23rd hour of the last day of the year of the Rabbit to get it to start.
This means that your car is likely flooding due to leaky injectors. You may also need a rebuild due to low compression.
Old Jul 14, 2008 | 07:25 AM
amemiya-7's Avatar
RXshun
has been rebuilt already, about 8000ks ago, and im pretty sure i got a set of injectors that had been tested and serviced etc
gxl90rx7
Haltech Forum
Sep 14, 2015 03:09 PM
ray green
1st Gen General Discussion
Sep 2, 2015 06:35 AM
