When racing gears grind when shifting
Old Jul 13, 2008 | 08:32 PM
Napsterfreak15's Avatar
Sometimes when I'm racing and I go to shift from 2nd to 3rd I press the clutch in but it wont go into 3rd. I hear a loud high pitch grinding noise like gears are grinding. This also happens sometimes when i shift from 2nd to 5th. Why does it do this?
Old Jul 13, 2008 | 08:44 PM
87 t-66's Avatar
not a drifter
best case scenario: you need new shifter bushings
worst case scenario: your syncro's are fucked and you need a new/rebuilt tranny
do you seriously have redsuns stickers on your car?
Old Jul 13, 2008 | 08:54 PM
alexdimen's Avatar
TANSTAFL
lol
Old Jul 13, 2008 | 09:36 PM
I replaced the top shifter bushings but im still having trouble shifting quickly into 3rd gear like it doesnt want to go in so ill replace the bottom shifter bushings i geuss.
Yes I have a redsuns sticker on my car. Why?
Old Jul 13, 2008 | 10:07 PM
p4nc7's Avatar
Passenger
If you took the time to replace the upper bushing, why not the lower one as well? Hell, while you're doing that, see if your shifter cup is in good condition.
SRSLY, redsuns sticker?
Old Jul 13, 2008 | 10:11 PM
NoDOHC's Avatar
Automatic = Power drain
I would guess it is synchronizers. If you race it a lot, they die quickly.
Old Jul 13, 2008 | 10:15 PM
BklynRX7's Avatar
King of the Loop
Ive had a s4 and 5 trans both with that same problem, shifter bushings didnt do anything, switching to royal purple gear oil made it a little better but , most likely they need rebuilds.
Old Jul 13, 2008 | 11:09 PM
zoneman2's Avatar
buy a new tranny get a used 1, cause its ur syncro im having same issue 2, 4 now if ur racing high 2nd then go into 4th or high rev 2nd throw into into neutral untill rpms egt to 2-3k then gently put it into 3rd or do it the easy n simple way...dont race
Old Jul 14, 2008 | 01:12 AM
initial D is REAL!'s Avatar
I told you Initial D is real!
Old Jul 14, 2008 | 01:16 AM
nunchuckgun's Avatar
mostly posts useless info
+1
Old Jul 14, 2008 | 02:19 AM
Aiden671's Avatar
i guess its real
i didnt really like redsuns all that much though
Old Jul 14, 2008 | 07:01 AM
RETed's Avatar
+bazillion
Odd though...usually the 1 -> 2 shift at redline will almost always crunch...
-Ted
Old Jul 14, 2008 | 07:56 AM
clokker's Avatar
Cake or Death?
Erm...because you're not supposed to shift from 2nd into 5th?
That just pisses 3rd and 4th gears off.
Old Jul 14, 2008 | 09:11 AM
Originally Posted by RETed
+bazillion
-Ted
Really, I've never heard a grind from 1st to 2nd. Its only when i shift to 3rd or to 5th.
Old Jul 14, 2008 | 09:13 AM
oh.?
Old Jul 14, 2008 | 10:04 AM
toplessFC3Sman's Avatar
if all your synchros are in working order, you can go from 2nd to 5th without a problem. The turbo transmissions are known for having weak 2nd and 5th gear synchros (I havent heard of 3rd going), but if you rev-match (and double-clutch if you're skipping gears up or down ) then you can get it to go into a gear with a worn-out synchro smoothly.
Old Jul 14, 2008 | 10:11 AM
junito1's Avatar
F**K THE SYSTEM!!
+bazillion
-Ted
Rly? Thats good to know. My tranny does the same thing when i try to shift to fast.
Old Jul 14, 2008 | 10:19 AM
Valkyrie's Avatar
Get some good synthetic gear oil and it might go away. (Redline or Royal Purple)
Old Jul 14, 2008 | 10:42 AM
Double clutching when skipping gears. thats also good to know. Thanks Topless
Ya lets see I'm using Castrol Synthetic for tranny fluid
Old Jul 14, 2008 | 10:46 AM
you only need to double-clutch if you're skipping gears and going into a gear with worn-out synchros. 2nd to 4th you should be fine, but 2nd to 5th you'd need to D-C
Old Jul 15, 2008 | 11:25 AM
Saavedro88's Avatar
Camshaft
Redline MT90 is your salvation. The 5 speed in my Supra was grinding like a **** when I bought it, so I changed out the fluid and put some Mobil1 tranny fluid in it. That did no good but I didn't have money to spring for a rebuild or a new/used one, so I drove like that for forever until I saw a thread about the amazing power of Redline MT fluid, and by golly if it wasn't all true!! I had to buy it online though cause I couldn't find a place locally that carried it.
But seriously... You have GOT to try that ****... and even if it doesn't work, you're only out, what, like $15?
Old Jul 15, 2008 | 02:11 PM
its that much better then castrol synthetic huh? I geuss i would rather try that then replacing my syncros..
Old Jul 15, 2008 | 05:45 PM
Saavedro88's Avatar
Camshaft
Yes and Yes.
BTW... RedSuns FTMFW!!! I'd totally rock that sticker...
Old Jul 15, 2008 | 06:41 PM
RETed's Avatar
The OP is ******* with anti-lag - see other thread.
No wonder the transmission is going to fall out of the car soon.
-Ted
thatfbtho
13
Aug 29, 2015 10:51 AM
NoMorePoison
11
Aug 18, 2015 11:18 AM
