Faulty ignition switch??
Old Jul 13, 2008 | 04:29 PM
Hypertek's Avatar
Slowpoke
so my car has always had this problem, you have to keep clicking the ignition to start.. Like you have to keep turning the key on and off for it to start, otherwise you just hear a click til it fires up..
I was told due to fualty solder joints in teh ignition?? i did a google search and cant find any info. I can solder if i need to. If anyone has some info id appreciate it. thanks.
Old Jul 13, 2008 | 04:44 PM
13Boom's Avatar
the same thing happens to me too. but i also have a bit of a melted harness under the dash. after i fix that if it still does it maybe i'll check into the switch
Old Jul 13, 2008 | 04:50 PM
87 t-66's Avatar
not a drifter
i have replacements
Old Jul 13, 2008 | 04:53 PM
Black Knight RX7 FC3S's Avatar
Turbo power, activate!
the clicking is from the starter?
It can be the ignition switch but you should also be wary of faulty connections and wires that leads to the starter.
Old Jul 13, 2008 | 10:17 PM
rotarybeat1287's Avatar
Visual Kei
sounds like my car back when my starter brushes were worn out. Had the starter rebuilt and cleaned up for $30 and **** spun so fast it fired right up every time. It would click like you described as well. I would try that out if you have the extra cash to spare.
Old Jul 13, 2008 | 11:46 PM
ppuppu9's Avatar
had that problem with my S14 back in the day...
got sick of it and put in one of those ricey push button starter, just replaced the relay on that thing and it worked like a charm.
Old Jul 14, 2008 | 12:23 AM
KhanArtisT's Avatar
Former FC enthusiast
My car does the same thing, and it hasn't gotten worse over 6 months so I just kinda forgot about it. I've had my starter and a reman. advance one and it still does it. I'm pretty sure its the ignition switch.
87 T66: how much for the replacements?
Bauer778
Nov 4, 2015 04:42 PM
ncds_fc
19
Sep 15, 2015 12:03 AM
meetRoX7e
Sep 11, 2015 11:09 AM
