where do these connectors go? (pics)
Old Jul 11, 2008 | 12:57 PM
87 t-66's Avatar
not a drifter
these are on the battery/starter/alt harness, everything as far as i can tell are plugged in...where do these go? they are on the harness between the starter ground and the reverse switch wiring.
this thing, not quite sure which harness its on?
Old Jul 11, 2008 | 01:04 PM
HAILERS's Avatar
HAILERS
Yellow/Red oil pressure sender. Can't see the wire color on the other in that picture.
Bottom pic looks like a gnd wire connection that should be near the wiper motor (bolts down) and the other end???on the engine? White part pulls right off the part with the hole in it. Right?
Old Jul 11, 2008 | 01:09 PM
87 t-66's Avatar
not a drifter
i think the top pic the wires are tan and black but i could be wrong. i do not have the oil pressure sender connected so that sounds about right. could the other one be the coolant sensor on the back of the motor?
the 2nd pic the white part does pull off the other part. its thicker than most of the wires in the engine bay.
Old Jul 11, 2008 | 01:15 PM
Whizbang's Avatar
Respecognize!
the coolant temp sensor connector is cylindrical, not rectangular.
the other wire looks like the ground from the bellhousing mating area to the firewall by wiper motor as Hailers stated.
Old Jul 11, 2008 | 01:22 PM
87 t-66's Avatar
not a drifter
which harness is the wire on in the bottom pic? i figured it was a ground but where does it go?
Old Jul 11, 2008 | 01:25 PM
Whizbang's Avatar
Respecognize!
no harness/
it only goes from an eye hole connection held with in with a bolt to the bellhousings then to the firewall with that metal piece.
Old Jul 11, 2008 | 01:29 PM
Funkspectrum's Avatar
no harness/
+1
Correct....
All FCs had a transmission to chassis ground. The chassis side is located just to the right of the wiper motor. The trans side is a 10mm bolt that bolts to the top of the bellhousing.
Old Jul 11, 2008 | 01:36 PM
87 t-66's Avatar
not a drifter
alright perfect...now what about the black wire in the top pic?
Old Jul 11, 2008 | 02:16 PM
The black wire in the top pic looks as if it's the oil pressure sender connector.
Old Jul 11, 2008 | 02:25 PM
87 t-66's Avatar
not a drifter
i dont think so, its too short.
ill have to look again but im thinking its for the coolant temp sensor as i know i dont have that connected either
Old Jul 11, 2008 | 02:34 PM
Whizbang's Avatar
Respecognize!
is the connector for a round connection?
Old Jul 11, 2008 | 04:04 PM
87 t-66's Avatar
not a drifter
im not sure, ill have to double check. i know for a fact these are the only 2 connectors not attached to anything and i know the oil pressure and coolant temp sensors arent hooked up. is the coolant temp sensor connector on the battery harness?
