I want to adjust my clutch engagement point, how to ?
Old Jul 9, 2008 | 06:41 AM
notveryhappyjack's Avatar
1 bar boost
I just put a new pressure plate / throwout in my car. The clutch used to engage right away, now I let the peddle all the way out to engage it. I bleed the clutch system correctly
What can I do to adjust this point ?
S2 RX7, S5 T2 Trans, S5 T2 Clutch master/slave, ACT Stage 3 pressure plate, ACT 6 puck, ACT 9lb fly
Help...Thanks.
Old Jul 9, 2008 | 06:50 AM
Falcoms's Avatar
kill it with BOOMSTICK!
There's a rod on the clutch pedal that goes to the clutch master that is locked on with a jam nut. Loosen the jam nut and turn the push rod out until the desired setting, then tighten the jam nut. Job done!
Old Jul 9, 2008 | 06:55 AM
Rotary?Cool's Avatar
top row 2nd from left..me
What he ^ said
Old Jul 9, 2008 | 06:56 AM
InsomniacFC's Avatar
Will drive for parts
In addition to above, it should have 3/16" to 1/2" freeplay.
Old Jul 9, 2008 | 08:01 AM
Falcoms's Avatar
^True, you should be able to push the pedal that far with just your finger before you encounter any force. Additionally, keep an eye on your free play, you will probably have to adjust it in about 30k-50k miles due to wear.
Skeese
Rotary Car Performance
Oct 28, 2020 11:01 AM
Microtech
30
Apr 23, 2016 06:37 PM
alphawolff
Nov 17, 2015 05:57 PM
CaptainKRM
14
Aug 26, 2015 09:52 PM
