jerkiness....fan mod responsible?
Old May 4, 2002 | 04:07 PM
bajaman's Avatar
Constant threat
I did the fan mod (ECU grounded to switch) and have noticed something weird: when I turn the switch to 'on' (grounding the wire) the car begins bucking and jerking badly, but only under light load conditions, i.e. if I am on the gas the jerkiness goes away. Same thing now happens (didn't before the mod) with turning the a/c on, so it must be cooling fan related.....anyone else have any similar trouble?
Old May 4, 2002 | 04:10 PM
j9fd3s's Avatar
Community Builder
if the ecu sees load it raises the idle, and if it sees load and there is'nt any it can get confused
mike
Old May 4, 2002 | 04:49 PM
bajaman's Avatar
Constant threat
The odd thing is, it just started doing it.....I have had the fan mod since last year.......
Just for grins I disconnected the wire to the ECU and have been driving all around, and...everything is working fine, no jerking.....
I wonder what that lower temperature sending unit
(from a Miata) part number is.....I think I would rather have the fans come on at a lower temp, rather than run longer with the car shut off anyway....or else do the OTHER fan mod, where you can simply turn the fans on anytime you want........
Turblown
Vendor Classifieds
Oct 17, 2020 03:25 PM
SSpyderX
1st Gen General Discussion
Sep 29, 2015 04:37 PM
