Rotary Drag Racing The place to post your racing stories and info
380lbs/hr injectors?....who makes these?
Old Jul 3, 2008 | 11:16 PM
dragFD's Avatar
on a post here in 20b section ther is a rx7 that is using 380 lbs/hr injectors from motec?..i rang motec today and they said they dont make them.does anybody know who does?...
heres a link to a pic of them...
http://i58.photobucket.com/albums/g2.../piston103.jpg
the 1600cc ones are 160 lbs/hr right?...
this makes 380 lbs = 3990 ccs/min?...
anybody on here know of these injectors...
any info appreciated...
ben.
Old Jul 4, 2008 | 03:46 AM
dragFD's Avatar
well have been looking into injectors for my drag project all day..
have spoken to many people about them..so far have found
2200cc from magnus motorsport...
http://www.magnusmotorsports.com/fuel/index.htm
3200cc from rc engineering
http://www.maximumvelocitymotorsport.../prod_106.html
and
basically what ever you like from mike morans site...
http://i207.photobucket.com/albums/b...-Orderform.jpg
http://i66.photobucket.com/albums/h2...jectors002.jpg
does anybody know what other big injectors are availiable bigger than 1600cc?...
or know who made the first ones i posted on here?....
ben.
Old Jul 5, 2008 | 10:48 PM
dragFD's Avatar
o.k got email from magnus motorsports they said 2200cc are on backorder..
and got an email from moran motorsports giving me a link to logg into his site will check that out..if can find any better info or pics of products will post them up here..
Old Jul 6, 2008 | 07:56 PM
dragFD's Avatar
this is from mike morans site...
EFI guru Mike Moran makes it easy for EFI engines to produce 1,000 to 4,000 HP with either gasoline or methanol, with the new M.R.E. PowerTip 5 fuel injector. Machined from a proprietary material, coated with titanium nitride, these PowerTip injectors flow from 150 lb/hr up to 600 lb/hr. The PowerTip 5 was designed as the first purpose built racing fuel injector. The injectors operate linearly with pulse width as small as 1.5 milliseconds and opens with the standard 4/1 amp peak & hold ECU drivers. Plus the M.R.E. PowerTip injector is a direct replacement for all standard injectors and are compatible with all aftermarket E.F.I systems out of the box, no injector driver adapters needed.
Order yours today, Starting at $235 each.
also i seen these intercoolers for big horsepower..
PT900 900hp Intercooler $900
PT1200 1200hp Intercooler $1200
PT1800 1800hp Intercooler $1800
PT2400 2400hp Intercooler $2400
Precision Turbo liquid-to-air intercoolers can be found in nearly every one of the cars that won 7 national championships, 5 special event titles and set 13 national records in 2006. Whether it was the Salt Flats of Bonneville or on the asphalt at Orlando, Indy and Vegas, our intercoolers have been in the Winner's Circle!
anyway though peop[le might like to know this
Old Jul 7, 2008 | 08:34 PM
kabooski's Avatar
Laying Down Rotary Law
wow awesome find! wayyyy better alternative then the Motec injectors
Queppa
Nov 18, 2024 03:47 AM
dkwasherexd
May 27, 2017 04:51 AM
