secondary injector probleme. please help
Old Jul 3, 2008 | 10:29 AM
RSL Cpt Mike's Avatar
hey everyone so heres whats happening. i have 1600 cc secondaries that arent working properly or possibly not coming on at all. when ever i go to get on the throttle its like hitting a wall and the car pops like crazy and wont move. i was on a dyno the other day and the rich and lean mixtures are some how fine untill i hit that point. im not sure if the resistors are blow or the injecters themselves. or what ne tips or suggestions let me know. thanx, mike
Old Jul 3, 2008 | 10:57 AM
2a+RoN's Avatar
Test the injectors to make sure they are opening/closing properly. If they have been recently cleaned sometimes the cleaning solution can make the pintle stick... If your ecu allows you to test outputs that's the easiest way, otherwise you can take them out and hook them up to 12 volts and listen to them click.
If they are working properly, I would first go over the setup in the ecu to ensure they setup properly. Also look into the wiring and just double check.
HalifaxFD
Canadian Forum
126
May 9, 2016 07:06 PM
ZacMan
Sep 19, 2015 09:20 PM
