tire size for 18x8
Old Jun 27, 2008 | 01:16 AM
RX7Crazy_84's Avatar
tire size for 18x8
finally got rims for my car but i was wondering whats the widest i can go with 18x8 rim(only for back). The rims came with tire already and the size was 225/35ZR/18. oh yeah rims are rpm2 45offset! i would greatly apperciate any help and yes i did look for it before i posted this
Old Jun 27, 2008 | 11:06 AM
BASTARD's Avatar
Every tire manufacture has a recomended tire to rim width spec for each tire
Old Jun 27, 2008 | 11:14 AM
Mahjik's Avatar
Mr. Links
245 is usually the largest you can do on a 8" wheel that's within most manufacturer specs. People go outside of those all the time though.....
Old Jun 27, 2008 | 07:08 PM
I wanted to go wide in the back. can I run 265 in the back safely?
Old Jun 27, 2008 | 08:03 PM
Mahjik's Avatar
Mr. Links
If you look at the tires you want to run (using Kumho's as an example):
http://www.tirerack.com/tires/Spec.j...irePageLocQty=
They have suggested rims sizes. Most 265's will recommend a minimum size of 9".
Old Jun 28, 2008 | 12:54 AM
how about 255 for the rearß and leave the 225 in the front
Old Jun 28, 2008 | 08:13 AM
Mahjik's Avatar
Mr. Links
You already have the information. Find the tire you want and check the specs. I'm not going to suggest running something a manufacture doesn't suggest. So, use your best judgment and run what you want.
Old Jul 11, 2008 | 04:36 AM
CarzArKoo1's Avatar
yeah u can run 255
SakeBomb Garage
Vendor Classifieds
Aug 9, 2018 05:54 PM
rx7jocke
72
Jun 17, 2016 03:48 AM
