interior fan not working
Old Jun 25, 2008 | 08:42 PM
onefastrx712a's Avatar
I did a couple searches and didn't find anything to help. I have 83 GSL and the fan won't blow. I have checked all the fuses and they are good. Is there like a squirrel cage fan in/under the dash that might be stuck? Any help would be great. Thanks in advance.
Old Jun 25, 2008 | 09:00 PM
StealthGXL's Avatar
I had this same problem, also thought my underdash fuses were good, make sure you check again . . I found one blown fuse and also discovered that the AC button has to be OUT not pushed in . . new fuse + AC button out and my fan finally worked
Old Jun 25, 2008 | 09:06 PM
thanks for the fast reply StealthGXL... I will have to wait till morning and check it out
Old Jun 26, 2008 | 12:32 AM
StealthGXL's Avatar
I have a non-AC car btw . .
Old Jun 26, 2008 | 06:05 AM
bliffle's Avatar
I found the fusebox blades electrically eroded when my 83 fan stopped. Cannibalized a JY fusebox for blades. If you have to replace squirrel cage motor it's only 3 bolts and 10 minutes work. I have a spare here if you're desperate.
streetlegal?
Mar 17, 2022 02:46 PM
rotor_veux
46
Jun 12, 2018 10:39 AM
immanuel__7
89
Sep 5, 2015 10:23 AM
