Missing while accelerating
Old Jun 22, 2008 | 09:54 PM
redbstd's Avatar
Red 84 SE
ok my cars an 84 gsl-se its got new plugs, cap, rotar, wires, i removed the acv, and cleared the cat. It starts easily but it misses severely when i accelerate to the point of were it berely moves.
What rpm should i hold it at to adjust timing? And if its not the timing what could it be? I have a new fuel filter but havnt installed it yet.
The aux port actuators move smoothly as well and my sensors are good as well.
Any help would be appreciated.
Old Jun 22, 2008 | 10:04 PM
Rx-7Doctor's Avatar
Timing is done at idle speed.
Need more history. How long has the issue been there? Did it occur after you did some work on the car?
Old Jun 24, 2008 | 02:48 PM
redbstd's Avatar
Red 84 SE
i got it that way. All the work listed i did. its strange it starts very easily.
should i do a compression test?
Will rotarys start normaly with a bad apex seal?
Old Jun 24, 2008 | 11:07 PM
djessence's Avatar
djessence
Did you check your timing?
My timing was quite off and it would start fine, idle on half choke no problem but wouldnt accel or idle after warmed up. double check your timing and vac advance perhaps.
Old Jun 25, 2008 | 12:42 AM
Jeff20B's Avatar
Lapping = Fapping
Yeah, timing. I advanced it slightly on the RX-4 today. Now it accelerates better. No more missing.
Old Jun 30, 2008 | 08:31 AM
redbstd's Avatar
Red 84 SE
its not missing now after i adjusted my timing. but it still wont idle for ****. Im thinking vaccum leak. so im going to replace my vaccum lines but if thats not it; any ideas?
Turblown
Vendor Classifieds
Oct 17, 2020 03:25 PM
Einheri
Oct 7, 2015 12:23 PM
Smokeyfb33
Old School and Other Rotary
Oct 1, 2015 12:10 PM
