Haltech unkown wires for e6k
Old Jun 21, 2008 | 08:59 AM
AlexG13B's Avatar
brap brap brap
Exclamation unkown wires for e6k
this is near the beging of the harness (where main connector is)
here what is the yellow wire for looks like next to conncetor for trailing coil? also i dont seem to find the other conncetor on the harness that goes to the trailing coil as well.
and not sure what these are?
i bought the haltech used obviously for my fct2. the prvious owner doest remeber some of the stuff since i bought it a few months ago and just now got around to installing it
Old Jun 21, 2008 | 11:09 AM
BASTARD's Avatar
according to the wireing diagram the yellow is either the CAS trigger or it could be the MAP wire , the green is CAS home or an auxilliary input
and the white 4 pin connector looks to be the CAS plug
http://haltech.com/downloads/E6Kdiagram.pdf
you never know what hacks or splices someone has made to a harnnes... the last person could have spliced a differnt color wire in ... best way to make sure which wire is what is to do a continuity test using a muli meter and test the pinouts
toplessFC3Sman
Mar 20, 2018 01:54 PM
DocHoliday89
Oct 12, 2015 07:42 PM
cosmo7
West RX-7 Forum
Sep 14, 2015 09:47 PM
