GiroDisc Brake Pad Spreader
Anybody got one of these? Worth the investment? I am really tired of pushing caliper pistons back in without a proper tool when changing pads, and I don't like opening bleed screws unless I'm also bleeding at the same time. This is like the tool the LeMans teams use to change pads during a pit stop.
http://www.zeckhausen.com/Tools/cali...n_spreader.htm
If it weren't $225, I'd have one.
Right now I use a channel lock with some rubber hose on the caliper side. If I had an old brake backing plate welded to the other side, it would at least do one side at a time easily.
I loosen my speed bleeders and use two pony clamps (one on each exposed piston), doing one pad at a time:
http://www.homedepot.com/webapp/wcs/...ctId=100120790
which is about 1/100 (ok, 1/50 since there are two) the price, and a lot easier to put in the toolbox. The blades are about the same width as the piston, so a little rocking back and forth is enough to get a cocked piston to go in.
Am I the only person who can clamp down a set of 4 pistons using the pad in place and my hand??? Seriously, it takes a sec, but I can do it! Anyway, just ordered myself one of those spreaders, I do enough brake jobs on the side that I think it will be worth it to own one. Especially with bigger vehicles.
Trending Topics
[For Sale] Scratch & Dent, Used, and Open-Box Sale!
SakeBomb Garage
Vendor Classifieds
Aug 9, 2018 05:54 PM
