interchangability?
Old Jun 14, 2008 | 01:22 AM
Mojoey89's Avatar
zoom zoom zoom
interchangability?
i have a 79 rx7 stock.
i want to get a short shifter. (miata short throw) does it matter what year i buy on ebay, most are 90-98 i dont want to get one if it isnt going to work so just double checking.
also the fuel gauge in the tank. will the ones for an 81-83 work for a 79 mazdatrix couldnt give me a definate answer.
Old Jun 14, 2008 | 01:28 AM
Mojoey89's Avatar
zoom zoom zoom
p.s.
heres the fuel sender http://mazdatrix.com/c-pump.htm
and here is one of the shifters http://cgi.ebay.com/ebaymotors/90-91...spagenameZWD1V
Old Jun 14, 2008 | 03:50 AM
7aull's Avatar
RX HVN
79-80 shifter unique (as is transmission underneath , so only option is to cut down existing shaft then re-thread for **** - was a popular mod when the car was new apparently
Fuel sender part number different (again, so is actual tank too) from 79-80s vs later RX7s - so it suggests these would not interchange...
Stu Aull
80GS
Alaska
Old Jun 14, 2008 | 09:28 AM
j9fd3s's Avatar
Community Builder
the shifter is what makes the SA cool!
the fuel sender, electrically works the same 79-85, so you might be able to take your old one and a new one, and get it to work
Old Jun 14, 2008 | 01:52 PM
Jeff20B's Avatar
Lapping = Fapping
If you want a short THROW shifter on an SA tranny, if you can find a 5 speed shifter from a '76-'78 ribcase trans, it will fit and shift correctly. All you'd need to do is shorten it to the SA length and rethread to oh let's say 12mm x 1.5 (or 1.25 whatever) like the '81-'85 *****. The throws will feel a lot shorter but the length will still look correct for the car.
I plan to do exactly this shifter swap on an SA tranny for the GLC before the new engine goes in.
Old Jun 14, 2008 | 01:55 PM
blackdeath647's Avatar
weak minds wear the crown
so, does that miata shifter work for an 85?, cuz the only short throw for an 85 i've seen on ebay it's like 150 bucks.
Old Jun 14, 2008 | 02:02 PM
Jeff20B's Avatar
Lapping = Fapping
I don't know. If I was going to do a short shifter on an FB tranny, which I doubt I'd do since it's already pretty short, I'd probably get the Mazdatrix one since it is a complete kit and truely offers short throws due to the lengthened distance between the large pivot ball and the small ball, kinda like the early ribcase shifters have.
I don't know what the Miata shifters look like, or the specs on lengths, diameters etc.
Old Jun 14, 2008 | 06:40 PM
j9fd3s's Avatar
Community Builder
no, the locating dowel thing moves from the back to the front in 81
Old Jun 15, 2008 | 11:42 PM
Mojoey89's Avatar
zoom zoom zoom
i was afraid of that. where can i find a NEW fuel sender gauge?
Old Jun 16, 2008 | 12:01 AM
Rx-7Doctor's Avatar
Have you removed yours and tested it per the factory service manual to see if it is your problem?
As far as where to get a new one for your year.
Don't know of any place that sells new ones for your year, best thing to do if you have tested,cleaned and determined that yours is bad. Is to post a WTB threadin the parts section.
Old Jun 16, 2008 | 11:18 PM
john ward's Avatar
oi oi oi
ive had one just seized up needing some tlc to free up the float and the pigtails like to break also with the age and corrosion
Wicked93gs
42
Oct 7, 2015 11:58 PM
BUSTN
V-8 Powered RX-7's
Sep 2, 2015 04:39 PM
travenport
Aug 29, 2015 11:15 AM
