Wheel Fitment question, i think this will work?
Old Jun 9, 2008 | 11:15 PM
shika805's Avatar
i am looking to purchashing these wheels for my 91 Vert,
fronts = 17x8.5 +30 offset
rears = 18x10 +24 offset
I am thinking these wheels will fit, i know my rears definately will clear with fender rolling or widen fenders. But my fronts i'm a little iffy on???? let me know if this will work guys?
thanks in advance!
Old Jun 9, 2008 | 11:45 PM
Josh18_2k's Avatar
fronts will work. depending on suspension, you can run 235-255 tires.
rear will def need a roll, or pull, depending on tire width
Old Jun 10, 2008 | 12:41 AM
shika805's Avatar
cool thanks a lot man! did you fender roll yours by yourself? looks well done in the pic
Old Jun 10, 2008 | 12:52 AM
Josh18_2k's Avatar
yah i bought an eastwood roller and went to town. i overdid it to be honest..
but its really not very hard to do nicely.
if you're gonna pull your fenders, id recommend only doing a little at a time, then test fitting till you get the desired clearance. i pulled the hell out of them, put the wheel on, and realized i had like an inch of extra room... haha
when i say test fit, i mean disconnect the strut, and just jack the wheel all the way up into the fenderwell
Old Jun 10, 2008 | 01:14 AM
shika805's Avatar
Good looking out man, i'll make sure to keep that in mind...
When you roll you fenders does it mess up with the paint finish on the fender? looks like it doesn't, i could be wong?
Old Jun 10, 2008 | 12:07 PM
Josh18_2k's Avatar
it'll crack the paint right along the edge, because you're folding it 180 degrees. i doubt any paint could survive that.. it didnt crack any where else tho.
they say to use a heat gun to help soften the paint, just in case.
Old Jun 10, 2008 | 05:27 PM
shika805's Avatar
aye bro, what width wheels you running in the back?
Old Jun 11, 2008 | 10:56 AM
Josh18_2k's Avatar
17x10.5 +27
275/40/17
astrum
24
Nov 15, 2017 08:44 AM
RaY358
Aug 19, 2015 11:44 PM
jza80
Aug 12, 2015 11:10 PM
