Power FC Feature to see if ignition is firing??
Old Jun 8, 2008 | 07:33 PM
SENZA PARI's Avatar
Is there any way to tell if the ignition is indeed firing using the PFC? The car will turn over but wont fire, and I know I have fuel....so I'm trying to narrow down my ignition problem.
Old Jun 8, 2008 | 09:10 PM
cewrx7r1's Avatar
Eye In The Sky
NO!
Unless you have an O-Scope, test it the way most people test it.
Old Jun 12, 2008 | 03:03 PM
Dudemaaanownsanrx7's Avatar
wannaspeed.com
just unplug one spark plug wire at a time and put a spare sparkplug in the boot. then ground the plug to the engine or frame, crank it over and see which wires fire. It is really not hard to do that. If you don't have a person that can crank the car over for you, run a seperate +12 v switch into the engine bay that goes to the starter so you can crank it over yourself while holding the plug.
killerrx710
Sep 24, 2015 10:57 PM
subeone
Sep 24, 2015 09:58 PM
Mps_hell
Sep 19, 2015 10:02 PM
SakeBomb Garage
Vendor Classifieds
Sep 7, 2015 03:44 PM
SakeBomb Garage
SakeBomb Garage
Sep 7, 2015 03:32 PM
