Sponsored by: CARiD
Headrest speaker compatibility with Mazda Miata?
Old Jun 5, 2008 | 11:30 AM
fourbanger's Avatar
Newbie
Hello rotary cousins - I'm visiting from over at miata.net and have a question about your cars. I'm posting it in the general forum since I'm not sure which generation applies.
Miatas use four 8 ohm 2x3 headrest speakers (actually 1-7/8" x 3-1/4"). It's a strange and hard-to-find size. I understand that some RX-7s also use headrest speakers. Is the speaker size and spec the same between the Miata and RX-7? Can I swap between them, and what model years apply?
I'm guessing that Mazda, in some bit of wisdom, might have unified speaker sizes across assembly lines.
Thanks!
Old Jun 5, 2008 | 12:13 PM
ehime's Avatar
肉*食*系*
I actually think that most of the headrest speakers we use come from
Miata buckets, but don't quote me.
Old Jun 6, 2008 | 06:59 AM
totpkg's Avatar
SC
The headrest speakers for the RX7's are only found in 2nd gen convertibles. 1988 - 1991, convertible only. Once you take the headrest apart the speakers are in their own hard plastic case, which is appx 2" x 4" ... speaker inside is 4 ohm and look to measure out to be about 2" (or little less) to 3.5" (or little less).
Numbers on the osd of the hard plastic case are F056 66 960 LH (obviously left hand) below that is (EAB - 980L)
The number on the speaker itself is: 9D05D
These are definately 4 ohm ... as it is listed on both case and speaker
I just happend to have one taken apart and was gona try and modify to install some Inifinity 3.5" rounds, but just haven't gotten around to it yet.
Hope this info helps ...
Ken
whinin
Mar 30, 2019 07:53 PM
astrum
24
Nov 15, 2017 08:44 AM
tiger18
Sep 3, 2015 08:27 PM
CynicalGambit
Aug 17, 2015 10:41 PM
