Megasquirt NA base map
Old Jun 2, 2008 | 10:53 AM
Trupain's Avatar
Mad Scientist
NA base map
I really hate to ask things that have probably already been asked but I cant seem to find a base VE map for for an s4 NA running MS II V3. Extra 29b firmware... I think.
can anyone point me in the right direction? also, I am running stock injectors (for now) Modified CAS. factory coils. no split. i got the timing pretty well covered but im having trouble with the fuel.
Thanks
Mac
Old Jun 2, 2008 | 05:11 PM
peejay's Avatar
Old [Sch|F]ool
There's a base map somewhere around here that's really "fat" but it will get a N/A started and running. It's a MS1 base-code fuel only map but if you translated the VE tables over it should work just fine. You should probably use its VE table with a 8ms req*fuel to start off with. It worked OK to get my N/A going after adjusting the req*fuel down to 6.4 to match my 680cc injectors.
Old Jun 3, 2008 | 10:38 PM
Trupain's Avatar
Mad Scientist
Thanks man! I'll hijack the VE table and see what happens
He's On Toroids
NE RX-7 Forum
48
Oct 19, 2015 08:58 PM
killerrx710
Sep 28, 2015 09:13 AM
killerrx710
Sep 24, 2015 10:57 PM
