Will not crank, nothing turns on, no lights
Old May 22, 2008 | 02:03 PM
pkel32's Avatar
Unhappy Will not crank, nothing turns on, no lights
its my daily driver, getting ready to go to work, hop in and nothing turns on, ok i thought to myselft. it must be the battery, so i jump it, still no good, then i bought a new battery and still nothing turns on!
What can it be!!
Old May 22, 2008 | 02:08 PM
Davin's Avatar
Back door, no babies...
Veteran: Navy
did you check your fuses? is your ignition switch good? do you have a bad ground?
we need info.
an rx7 as a daily driver is not a good thing
Old May 22, 2008 | 02:14 PM
SLOASFK's Avatar
Top's always down
Check your fuses, like Davin said... Also, check your grounds.
Where are you in PA?
Old May 22, 2008 | 05:39 PM
pkel32's Avatar
i'm in mechanicsburg, pa, i check all the fuses and they are all ok, i even put in a new main relay. still nothing turns on
Old May 22, 2008 | 06:04 PM
SLOASFK's Avatar
Top's always down
have you tried turning on the headlights or the 4-ways?
Old May 22, 2008 | 11:22 PM
pkel32's Avatar
nothing turns on headlights, 4 ways, interior lights
Old May 22, 2008 | 11:26 PM
SLOASFK's Avatar
Top's always down
in that case, it's probably going to be something painfully stupid. Did you check your grounds? Start with the negative battery cable. Make sure the connection to the terminal is secure and that the wire isn't torn, then follow the ground all the way to the chasis.
Old May 23, 2008 | 09:41 AM
johnnydngrs's Avatar
sounds like it might be a relay, might want to check those
Old May 23, 2008 | 02:19 PM
gafu mazda's Avatar
el unico
try checking the relay box in front/top of radiator
Old May 23, 2008 | 08:34 PM
pkel32's Avatar
Found out what the problem was, it was the positive terminal battery wire adapter that goes on the battery,The terminal was wear out so i replaced it and starts rite up, something so simple cause me so much headaches. thanks for everyone's help
Old May 23, 2008 | 09:31 PM
SLOASFK's Avatar
Top's always down
congrats. I was close
Boriquaguerrero
20
Apr 22, 2019 01:15 PM
RPOdesign
Aug 27, 2015 11:42 PM
PhillyFC
Aug 21, 2015 06:36 PM
