Defined Autoworks Race prep, Dyno tuning, Rotary Performance, Unique Fabrication and Transplants
V-mount FD with electromotive install for customer
Old May 21, 2008 | 05:22 PM
GtoRx7's Avatar
Collections Hold
This is a V-mount setup we did over a year ago on a mostly factory FD (FDwarrior). We modified the y-pipe and other items making it non-seq in the process as well. Note that everything is rubber supported so that the radiator and intercooler will never break. Also installed the electromotive Tec GT into it with custom coil mount. The engine was a old reman, and this is why its not so shiny and clean . We just started with the management and getting it to run cool and strong. Figured I would post up some pics as people were asking about v-mount setups.
Old May 21, 2008 | 05:23 PM
GtoRx7's Avatar
Collections Hold
Old May 21, 2008 | 11:56 PM
Trjackson's Avatar
Logan, don't forget to post the dynograph where the car made what 400 ft lbs?
Jackson
Old May 22, 2008 | 09:08 PM
GtoRx7's Avatar
Collections Hold
Well it wasnt quite 400ft-lbs but it was close enough at 385 rwtq. Stock twins, stock ports on 93 octane. I am certain the electromotive is largely responsible for the engine taking this abuse on many occasions while the boost controller was having some issues.
Old May 22, 2008 | 10:15 PM
CyborgRyu's Avatar
Drift FC
How is that possible? More tq than hp?
Old May 22, 2008 | 11:59 PM
twisted7's Avatar
Jake
my engine always made more tq than hp to begin with. it would of been a matter of time before the hp caught up to the tq and it begins to fall off.
Old May 23, 2008 | 02:09 AM
dregg100's Avatar
5250 rpm is where the HP crosses the TQ and becomes greater. the graph only shows to 5025, therefor tq is higher.
Old May 23, 2008 | 06:23 AM
FDWarrior's Avatar
Defined Autoworks
Another thing to remember is my car dose not always make these numbers. Its not like Im driving around like this. The boost controler had an issue and allowed the stock twins to spool up to 32psi or so. I must say it was fun when I did on the street.
Old May 23, 2008 | 11:01 AM
GtoRx7's Avatar
Collections Hold
21 psi to be exact. 32psi would have been very insane.
Old May 23, 2008 | 11:18 AM
Thadeous's Avatar
What kinda fans are you using on it? push/pull ect
Old May 23, 2008 | 01:39 PM
FDWarrior's Avatar
Defined Autoworks
When frank was in the car on 16 coming home from NAPA my boost gauge pegged at 32psi. Ask Frank, it was insane, and fun.
Old May 23, 2008 | 05:00 PM
FDWarrior's Avatar
Defined Autoworks
^ wow Im a retard, my gauge did peg but it is only 21 psi. I guess we all have a retard moment every once in a while, it was still fun.
Old May 24, 2008 | 12:28 AM
FDWarrior's Avatar
Defined Autoworks
Im using a flexalite fan. The fan is a pull type.
82streetracer
Aug 23, 2015 09:28 AM
gabescanlon
Interior / Exterior / Audio
Aug 11, 2015 05:59 PM
