Question about Injectors
Old Apr 30, 2002 | 05:05 PM
Yelow RX-7's Avatar
Swingline Stapler
my friend is looking to get about 400rwhp with his 87 TII. he is wondering if 1000cc injectors would be adequate enought to suit his needs. please respond with any thoughts or opinions. TIA,
John
Old Apr 30, 2002 | 05:24 PM
E6KT2's Avatar
I have the same goal, and of course, the E6K. WHich fuel injector setup will work best to achieve ~400hp? If I buy the K2RD 1600cc secndary set-up which primaries do I need? Thanks.
Old Apr 30, 2002 | 07:48 PM
Ranzo's Avatar
http://www.rceng.com/technical.htm
Check out this page for information on how to figure the size of injector you would want.
I know you can make 400hp with only 720's in the secondaries but nothing about me is conservative.
To be safe you could look at copying the FD3S setup and run 850's in the secondaries, or you could play with fuel pressure to put you in the area you want to be.
Old Apr 30, 2002 | 09:16 PM
E6KT2's Avatar
So your saying that 550cc primaries plus 720cc secondaries will support 400hp?
Old Apr 30, 2002 | 09:18 PM
NZConvertible's Avatar
I'm a boost creep...
4 x 1000cc/min injectors are good for ~530hp. 2 x 550cc/min (stock) and 2 x 1600cc/min are good for ~570hp, and means only buying two injectors. 1000cc/min primaries might mean a poor idle as well.
Old Apr 30, 2002 | 09:37 PM
Ranzo's Avatar
Yes that is what I am saying, I am sure that many people can give formulas and reasons why you can't but it can be done. This might look sketchy but this is not using a 80% duty cycle and not using stock fuel pressure. It has been my experience that the pintle type injectors work good above 80% .
To be on the safe side I would reccomend something larger than a 720.
Skeese
65
Mar 28, 2017 03:30 PM
morataya
Microtech
Aug 16, 2015 09:39 AM
