Sponsored by: CARiD
ERRRR!!!!! ROAR! 3500 rpm turbo cutoff
Old May 19, 2008 | 11:56 PM
stubble88's Avatar
Why is it when Im not looking for something its everywhere and when I need it its nowhere to be found??
Where is the write up on the 3500 rpm turbo lag cutoff thing that involves a better ground?
please help
If its on Robinette's site please tell me exactly where,
I HAVE SEARCHED FOR THIS SO DONT TELL ME TO SEARCH, JUST TELL ME WHERE IT IS.
thanks
Old Jun 21, 2008 | 01:09 AM
nb7's Avatar
nb7
What?
if you find it will you post where same problem maybe not sure what is going on.
Old Jun 21, 2008 | 01:41 PM
MOBEONER's Avatar
It's finally reliable
haha that happens to me all the time
Old Jun 21, 2008 | 04:18 PM
RotaryBred's Avatar
Lost You in the Rear View
turbo cut?? sounds more like a bad charge door actuator or vac. line, or possibly a bad solinoid. a bad ground only causes hesitation. check your charge door actuator and make sure its still connected. sometimes the clip rusts and breaks off so the actuator rod is just hanging.
the fix with the grounds is just to clean the connections very well. it isn't neccesary to add grounds, but if you do choose to, the best place is to add one to the top of each housing above the spark plugs to the fender. home depot sells little junction blocks that mount right to the fender and look nice and clean.
Kyo
Apr 13, 2019 09:24 AM
CaptainKRM
14
Aug 26, 2015 09:52 PM
Microtech
Aug 23, 2015 11:04 AM
