oil leak and weak boost. any ideas?
Old May 19, 2008 | 06:30 PM
karl0003's Avatar
WA oil leak and weak boost. any ideas?
so i went down and picked up a t67 single turbo fd this weekend from Arizona. the seller told me there was a oil leak and i had no problems with it the entire drive back to Washington. today i drove the car and all the gagues and power fc were reading fine but as soon as i reached the point where i usually would hit full boost the max psi it would run was 1. im not sure if this is caused by the oil leak but if anyone has any ideas please let me know. thanks.
Old May 20, 2008 | 04:48 AM
ahad's Avatar
dude 9 outta 10 times oil leak and weak boost is a sign of a finished turbo...im not saying thats the cause but u shud have ur turbo looked at...see how bad the play is...
Old May 20, 2008 | 03:13 PM
afterburn27's Avatar
Lets Go Hokies!
It sounds like you may have a boost leak.
As for the oil leak... can you visually inspect where the oil is coming from? "oil leak" is a bit vague, haha. Is it external on the engine somewhere? Leaking on the ground? Oil in the intake?
Old May 21, 2008 | 02:38 PM
Dudemaaanownsanrx7's Avatar
wannaspeed.com
do you hear a whooshing noise from the engin area when you try to boost. i agree it sounds like a boost leak, or maybe your wastegate is stuck open. most turbos will still boost, they just start adding a bunch of oil along with the boost. or the turbo wheels could generate enough slop to start rubbing. pull the air cleaner off and see if you are able to spin the wheel by hand. (engine off)
Old May 21, 2008 | 09:11 PM
karl0003's Avatar
the car has a small leak coming from the oil filler neck. that is where the leak is from
Old May 21, 2008 | 09:13 PM
karl0003's Avatar
i took my intake off and the turbine wheel spins fine. im going to rin sea foam through it tomorrow and see where there is a leak if its from a coupler vac line waste gate or turbo. thanks for all the help guys
Kyo
Apr 13, 2019 09:24 AM
Cameron38
Aug 19, 2015 06:08 PM
sypath
Aug 16, 2015 12:06 AM
