copper crush rings
Old May 19, 2008 | 01:12 PM
Sideo's Avatar
copper crush rings
hi guys, i remember looking through a thread and members were having trouble getting new copper crush rings, specifically the big ones for the oil lines. Well i work at walmart were they do oil changes, and i found out that the copper crush rings we have for drain plug gaskets fit. theres rings that fit the oil lines, and different ones that fit on the omp injectors. If anyone needs some of the copper crush rings they should go to a walmart oil change place and see if they have any, or i can mail you some if you need.
Old May 19, 2008 | 01:16 PM
Mahjik's Avatar
Mr. Links
You might measure to make sure they are an exact fit. I tried some local ones before that I thought were the size. However, it turns out they were a little off. This cause a leak which I eventually just had to order the correct ones from Ray.
Old May 19, 2008 | 01:19 PM
Sideo's Avatar
ok, ill check to make sure.
edit: my calipers are at my apartment, ill measure when i get a chance.
MILOS7
Oct 1, 2015 08:00 PM
